Engine brackets
Old May 28th, 2017, 12:18 PM
jRoofgunner's Avatar
Engine brackets
I need some guidance regarding which brackets or where to get them for my build. I have a 65 Cutlass with PS/PB and alternator. (NO AC) It has the 330 4BBL motor. I had an engine built which is a 425 "D" block(455 crank), Pro Comp heads and an Edelbrock 455 Olds manifold. The issue is that I have tried to use the 330 engine brackets to hook up the PS and alternator and I can't see how they will work. The top bracket for the PS pump will fit but the bottom won't. The bottom alternator bracket would bolt on to the head but the top bracket will not meet up with the bottom and no way will it work. I have the correct water pump and crank pully and they are fine. The engine is fine with 470 hp and 540 lbs of torque w/W manifolds.
Thank-you in advance.
jRoofgunner is offline
Old May 29th, 2017, 05:19 AM
lemoldsnut's Avatar
65 had some variations in brackets and not all of them cross over. I can help you with brackets that will work.
Email direct lemoldsnut@aol.com
Larry
lemoldsnut is offline
Old May 29th, 2017, 06:38 AM
I got the PS side altered after some work. This shows the difference in what I think is the difference between a 330 bracket and a 425 bracket when it comes to the water pump attachment.
Old May 29th, 2017, 07:42 AM
Gee, that looks like just about the 1" difference in deck height from SBO to BBO...
In 1965, the SBO and BBO accessory brackets were different due to the deck height difference. You need the correct BBO brackets for a 1965.
joe_padavano is online now
olddaz
August 27th, 2014 06:39 PM
ERIC27
March 3rd, 2013 11:14 AM
rayfrausto
June 24th, 2011 11:41 PM
ctrain22
May 5th, 2009 07:21 PM
smyrna ranch
August 3rd, 2008 12:13 PM
Quick Reply: Engine brackets
