Broadcast Card Questions - '70 W30
Old May 7th, 2017, 11:38 PM
35olds's Avatar
I was just wondering if there may be some more knowledgeable people out there that could tell me what info was really covered on a "Broadcast Card". My '70 W30 came with the card and everything matches but as I understand it these were from Fisher Body ???? So, whilst my card shows the W30 option I was wondering if these cards typically had other codes like the W27 rear axle etc that were more related to the drivetrain than the body. Obviously the axle codes wen't on the cards but were options like W27 on them ??
Attached is my broadcast card with the last 2 digits of VIN edited out.
35olds is offline
Old May 8th, 2017, 01:13 AM
35olds's Avatar
Sorry, I should have searched more threads on the site. Think I've answered all my questions with a bit of research. Thanks all.
35olds is offline
Old May 8th, 2017, 05:30 AM
jharsh's Avatar
So, what answer did you come with?
jharsh is offline
Old May 8th, 2017, 05:42 AM
35olds's Avatar
Well from numerous threads I've read, the common theme was that the Broadcast sheet only lists the options that effected the build of the body of the car and what Fisher had to provide. So driveline options like the W27 technically wouldn't have been listed because it didn't effect the body build. Well that's how I've interpreted it so far.
Having said that, there are many cars that should have had codes on their Broadcast sheet as they had options which required specific input from Fisher - but strangely many Broadcast sheets don't specify those options.
35olds is offline
dgp1042
March 10th, 2016 03:49 PM
70W30Jim
March 1st, 2016 12:37 AM
halfmoontrail
March 6th, 2015 09:28 AM
montvaleplace
December 27th, 2011 09:23 PM
344870M
August 25th, 2009 03:28 AM
Quick Reply: Broadcast Card Questions - '70 W30
