69 442 Options
Old July 25th, 2016, 12:36 PM
My2nd 69 442's Avatar
69 442 Options
I have recently purchased a Beautiful 69 442. I have spent a good deal of this morning reading posts of Vin # decoding, but did not find any answers to my question. My question to the many Olds experts here is: Is there any way to find what Options my car was originally produced with.Body by Fisher reads as follows.
ST 69-34487 BF 03231 BDY
TR 933 B80 69 69 PNT
04B 142597 660709
No other tags or build sheets have been found yet.
Car has 400 BB, 4 speed (Close Ratio), AM/FM stero, Rally Pac gauges with Tic Toc Tach, AC, Power Steering, Power Brakes, SSII wheels(14 in) Bucket seats w/ console. Can't thing of any other present options at this time.
Any help will be greatly appreciated.
Jerry
My2nd 69 442 is offline
Old July 25th, 2016, 02:01 PM
04B 142597 660709
Jerry
Sorry, but that info is really not in the VIN or cowl tag, and records no longer exist. The only option even listed on the cowl tag is B80, the bright drip molding. Unless you find a build sheet, you are out of luck. Of all the Oldsmobiles I've owned, I've only found two build sheets, one in a Fremont car like yours and one in a Framingham car. Both were on top of the gas tank.
joe_padavano is online now
Old July 25th, 2016, 02:29 PM
Thanks Joe for the fast response. You have told me what I was afraid of. I do intend on removing the tank in the near future so maybe I'll get lucky. Not betting on it but stranger things have happened.
Jerry
Old July 25th, 2016, 03:10 PM
Randy C.
rcorrigan5's Avatar
Here's what your trim tag does say.
ST 69 = style/model year = 1969
34487: 3 = GM division = Oldsmobile, 44 = model series = 442, 87 = body type = holiday coupe
BF = assembly plant = Fremont, CA
03231 BDY = Fisher Body number assigned by Fisher Body; has no relation to your VIN
TR 933 = interior color and front seat type = blue interior with bucket seats
B80 = option code for exterior drip scalp mouldings
69 69 PNT = lower and upper body colors = platinum for both
04B = time build code = April (04), second week of that month (B), 1969
Your VIN should look like 344879Znnnnnn where n = a six-digit sequence number assigned at the assembly plant
There are ways of telling if certain items are original to your car. The VIN derivative (39Znnnnnn) will be found on your engine block on a raised pad on the driver side of the block below and slightly forward of #1 cylinder. The same VIN derivative will be stamped vertically on the driver side of your transmission housing.
There is a pamphlet published by SuperCarsUnlimited in Beaverton, OR, titled "4-4-2 By The Numbers" that will tell you a lot about your car. You can order it from their web site (www.supercarsunlimited.com) if you like. Their motto: "4-4-2 is all we do"!
I also highly recommend purchasing a hardcopy version of the "1969 Oldsmobile Chassis Service Manual", a hardcopy "Body By Fisher 1969 Service Manual", and a 1969 4-4-2/Cutlass Assembly Manual. All are invaluable in learning about, and conducting maintenance and repairs on, your 4-4-2.
Randy C.
rcorrigan5 is offline
Old July 25th, 2016, 05:30 PM
Platinum with blue interior. Sounds like an unusual and sharp-looking color combo.
Old July 25th, 2016, 06:50 PM
Thanks Joe
I think this car is sharp. It's almost exactly like the one I owned in 1969 except that one also had a blue vinal top. I have a couple pics in another post here. I'm not very computer literate or I would attempt to post additional pics.
Old July 25th, 2016, 11:56 PM
Diego's Avatar
Are you sure it has a M21 and not M20?
Diego is offline
Old July 26th, 2016, 12:45 PM
I believe that it is a close ratio M 21. The #'s on the gear set are 3A72 GM ZG 337. If anyone can de code these #'s, then I can know for sure.
I may attempt to convert to a M 20 later on. I like the wide ratio much better.
Jerry
Old July 26th, 2016, 01:59 PM
Diego's Avatar
The rear gears you have tend to be M20 gears but that's in the Pontiqc world, and I don't have any docs to reference at the moment.
Edit: meant to say the tranny with AC tend to be M20 for Pontiacs.
Diego is offline
Old July 26th, 2016, 02:04 PM
Per the 1969 SPECS booklet, M21 was not available with A/C. 3.23 was the standard rear axle with M20 and the steepest gears you could get with A/C.
Old July 26th, 2016, 03:39 PM
Thanks for the print out. I was scheduled to receive my manuals today but the good ole post office sent them to a complete different city so who knows when I may get the manuals now.
Old July 27th, 2016, 04:04 PM
Received my Chassis Service Manuals today so maybe I won't be asking you guys to do research for me that I can now do myself.
Thanks for the info you guys gave me Now I just need to learn how to use this site much better.
Jerry
Old July 27th, 2016, 06:30 PM
I now must agree with the experts. I must have a M 20 diff. I thought with the way it winds thru the gears that it had to be close ratio, but I stand corrected. I guess that my memory is failing me in regards to how my original 442 drove in the 60's and early 70's.
Sure sucks getting old
Jerry
Old July 27th, 2016, 08:19 PM
dualgate1968's Avatar
there are numbers on the side of the trans, start with a P and usually end with a letter (A M20, B M21, C M22), that will help decode what it is. That doesn't guarantee what is still inside however, but we would know what it was originally.
dualgate1968 is offline
Old July 28th, 2016, 04:15 PM
Thanks, next time I put the 442 on the lift I'll check all identifying numbers. I have my 67 Camaro convertible on the lift right now.
July 5th, 2012 09:34 AM
RAMBOW
March 23rd, 2009 02:05 PM
Dirty hairy
September 30th, 2008 10:28 PM
desert442
March 28th, 2008 01:07 PM
Topless72
February 2nd, 2008 08:37 PM
Quick Reply: 69 442 Options
