68 OAI scoop questions
Old October 22nd, 2014, 06:21 PM
karfever's Avatar
I have searched around but have not come up with the mounting questions on the 68 under bumper scoops.
What was used to mount the brackets to the plastic scoop. Rivets? Or?
I assume that the brackets then are bolted to the radiator support. Bolt through or?
Thanks for any responses!
karfever is offline
Old October 22nd, 2014, 06:25 PM
costpenn's Avatar
Correct - rivets were used to hold those L brackets to the body of the scoop.
costpenn is offline
Old October 22nd, 2014, 06:41 PM
Octania's Avatar
Pretty sure the brackets go to existing holes in the core support.
Dang I should know this but my '68 has never had its OAI since I got it
the parts are stored in the garage.
Assembly manual perhaps has details
Octania is offline
Old October 22nd, 2014, 06:48 PM
costpenn's Avatar
Yes, they go in existing holes in the core support - if I remember, a couple of the LH ones use the same bolts that hold the battery tray down.
costpenn is offline
Old October 22nd, 2014, 08:22 PM
dnmfranco's Avatar
you will need 12 rivets per scoop
as mentioned all holes in core support
have pics somewhere on the ram rod I use to own , try to dig them up
dnmfranco is offline
Old October 22nd, 2014, 09:34 PM
70Post's Avatar
If '68 scoops are similarly constructed as the '69 scoops you will also want to use the "backer" washers under the rivets on the insides of the scoops. ALL rivet points used these washers on the '69 scoops. These help spread the load/reduce concentrated stress on the plastic scoop surface. First pic below shows these on a set of '69 scoops I restored. Other pics are for general enjoyment/entertainment.
70Post is online now
Old October 22nd, 2014, 10:42 PM
How did you crimp the stainless trim on, and what determined the correct spot to place the crimps?
1969w3155 is offline
Old October 22nd, 2014, 11:12 PM
70Post's Avatar
The crimps were there from the factory....it's been 3-4 years since I did them but I believe I used a punch/tap with hammer on the outside while holding a dolly on the other side (could have used at least one extra arm/hand doing that!). May have mounted the dolly in a vice to hold it so I could deal with the punch and hammer with my hands.
With some imagination you could probably make a hand-held crimper using a cheap pair of plain old adjustable pliers with a backing plate on one jaw and a sort of raised dimple/punch form on the other.
Some of the stainless trim pieces were in pretty sad shape..."before" pics of one of them below:
Old October 23rd, 2014, 04:46 AM
karfever's Avatar
Thanks for the replies. I am going to have to look again, but I dont remember any pre-existing holes in the radiator support near where the braces would be, BUT the PO on this car didnt care, he just used some glue and stuck them on! Needless to say that idea didnt work well and at a show in Florida last weekend, a friend came up and told me that one of the scoops was laying on the ground. A bit embarrassing!
karfever is offline
Old October 23rd, 2014, 08:18 AM
I have a set of replacement stainless that I bought several years ago, but they have no dimples in them, I had thought of doing the adjustable plier thing, just was concerned with the correct location and size of the crimps.
Old October 23rd, 2014, 06:08 PM
w30hurstolds's Avatar
1968 ram air
here are my nos 1968 scoopes
w30hurstolds is offline
Old October 24th, 2014, 04:48 AM
karfever's Avatar
Great photos W30, thanks
Does anyone have a photos or two of the mounting of the brakets to the core support?
karfever is offline
Old October 24th, 2014, 09:08 AM
hurst68olds's Avatar
here's a couple pics
hurst68olds is offline
Old October 24th, 2014, 09:39 AM
karfever's Avatar
PERFECT! Thanks to all who responded!
karfever is offline
Old October 26th, 2014, 05:31 AM
karfever's Avatar
Looks correct now (pictures)
karfever is offline
Old October 26th, 2014, 05:40 AM
looks good!
tbirdman
November 21st, 2013 02:13 PM
camshaw
August 17th, 2013 10:09 PM
grmchne78
July 23rd, 2012 06:41 PM
WTony
April 13th, 2011 02:55 AM
4speedBench
April 17th, 2010 05:08 PM
Quick Reply: 68 OAI scoop questions
