68 cutlass/442 decklid question
Can some verify that a 68 4 door cutlass decklid is the same as coupe decklid or is it common to the convertible for the 68 model year?
thank you
thank you
The easy way to tell is to look at the upper corners. Square corners = coupe. Rounded corners = convertible or more-door. This is why you see more "convertible" trunk lids for sale than there were convertibles made by Olds. Also note that the convertible trunklid is overall narrower than the one on the coupe. Note where the lower corners of the trunklids fall in relation to the tail lights.
