442 restoration questions
Old August 8th, 2008, 09:29 AM
tkw31's Avatar
is the original carpet on a '70 442 2 or 3 sections? the one in our car looks original, but the front section is 2 peices under the front buckets and then the rear part.
does anyone know the correct plating or paint finish for the following items? 4 speed shift linkage and reverse lockout linkage? hood latch and hinges? coil bracket? lower control arm bolts and nuts? upper control arm shaft washers and nuts?
has anyone ever found a build sheet above the gas tank on a lansing built 442 or W car???
thanx!
tkw31 is offline
Old August 8th, 2008, 08:37 PM
Sounds like someone might have "modified" your carpet or replaced the front. To my knowledge, your car should have a 2 piece carpet. Having buckets shouldn't make any difference to the carpet. It just means that there are different hole patterns for the seat mounts/tracks. The carpet should be a jute back 80/20 loop, and both back the front carptets were "preformed" to fit the contours of the floor pan and trans hump. If the carpet is split under the console, I would suspect a backyard repair.
Good question about the build sheet. Never found the actual build order, but I found 3 broadcast sheets in my car. 1 tucked into the dash wiring loom, 1 under the front carpet, and 1 on top of the gas tank when I had to take it out for a leaking filler neck (The sheet wasn't in very good shape but was recognizable for what it was). My car was built in Lansing 04/72.
Allan R is offline
Old August 11th, 2008, 08:23 PM
stevengerard's Avatar
3 oldsmobiles - no buildshhets from lansing
stevengerard is offline
Old August 11th, 2008, 09:26 PM
is Fast Enough ...
mugzilla's Avatar
who has the best carpet ...?
I need one for my '70 ...
mugzilla is offline
Old August 12th, 2008, 05:57 AM
I know Kanter sells reproduction carpets for classic cars. However, I think they are generic. There is also a place called EZ Rod Interiors (I think that is right), they do generic interior items for most muscle and classic cars.
Olds64 is online now
Old August 12th, 2008, 07:03 AM
Junior Member
88 coupe's Avatar
Originally Posted by tkw31
........ has anyone ever found a build sheet above the gas tank on a Lansing built 442 or W car?
http://www.realoldspower.com/phpBB2/...=481639#481639
Norm
88 coupe is offline
Old August 12th, 2008, 08:13 AM
is Fast Enough ...
mugzilla's Avatar
I got a rug from original parts group and It was like chevelle quality ...
I ordered a under hood and light harness from brothers auto product they
say they compete at shows. I also ordered a set of door handle gaskets as
the ones from opg were a joke...
mugzilla is offline
Old August 12th, 2008, 07:33 PM
442=A perfect 10
GoodOldsGuy's Avatar
Try www.accmats.com I have them in my 68 and they are direct replacements for the originals.
Regards,
Fred
GoodOldsGuy is offline
Old August 12th, 2008, 08:15 PM
is Fast Enough ...
mugzilla's Avatar
Regards,
Fred
Looks like a quality piece ...
Thanks ...
mugzilla is offline
Old August 13th, 2008, 09:11 AM
tkw31's Avatar
we've used ACC in the past. they fit well and are good quality. the only issue i have is they seem to get fuzzy. i can't find anyone's carpet that has the look and feel of original carpet.
tkw31 is offline
Old August 13th, 2008, 10:40 AM
is Fast Enough ...
mugzilla's Avatar
I almost bought a cherrry cutlass just to ravage NOS pieces. I got out bid though ...
mugzilla is offline
Old October 25th, 2008, 07:19 PM
70' W-30 Convertible
442's Avatar
I bought carpet from this site twice:
http://www.autotrimsupply.com. Seems to be of good quality, they appear to be selling the ACC products but about 1/2 the price. I bought both carpets with the mass backing option which really quiets things down.
442 is offline
Del70
July 21st, 2020 11:42 AM
68Tom
January 12th, 2011 07:40 PM
65az
July 30th, 2009 02:08 PM
fatboy578
November 12th, 2008 10:23 AM
mr-tom
June 16th, 2007 11:34 PM
Quick Reply: 442 restoration questions
