442 front end droop
Old March 31st, 2010, 06:56 PM
olds..older..oldest
derek nesdoly's Avatar
442 front end droop
Just got the red beast back from the alignment shop. The mechanic there noted the front right side was a little low.I told him we just replaced the coils on all 4 corners in the late fall. He's in his mid-50's , and said he thought he remembered something about the 442's of this vintage having this right front dip problem. Do any of you older and wiser 442 fans know anything about this? I wondered if I would have to go with a 1/2 turn taller coil on the right? Thanks , D.
derek nesdoly is offline
Old April 1st, 2010, 05:22 AM
4fortwo's Avatar
I know in '69 they used high range springs on the left side and low range on the right. What springs did you use last fall?
4fortwo is offline
350TurBRO
September 12th, 2014 11:52 AM
raw442
October 9th, 2012 07:09 PM
cutlassmoe
February 12th, 2011 06:40 AM
johnyyy
September 10th, 2008 06:23 PM
Fred H
January 12th, 2008 05:38 PM
Quick Reply: 442 front end droop
