1970 Olds 442 Developed Mushy Brakes(Power Front Disc)
Old August 26th, 2018, 07:49 PM
dinanm3atl's Avatar
On the way to a show on Saturday after I stopped for breakfast I lost what is normally a pretty nice feeling pedal. I was close to the show so finished off the drive just allowing extra stopping distance. It wasn't feeling unsafe just went mushy. Parked it and walked around looking at cars while it cooled down a bit under the hood.
-Checked fluid and the front reservoir is low.
-Since front was low I inspected front calipers and inside wheels. No fluid
-Where the master meets the booster it is damp and looks like some fluid might have been dripping down there and the paint is bubbling slightly
So it sounds like I might have a leak inside the master that is leaking into the booster. At least from my experience this might be the case.
Anything else to check? And recommendation on where to buy these parts? And once acquired anything special to bleed this setup? None of my BMWs have bleeders on the resevoir/master. I'd just use a power bleed at the calipers and then do a couple manual activation per corner.
dinanm3atl is offline
Old August 27th, 2018, 08:19 AM
It could also be a leak between the front and rear pistons in the M/C, but either way, it's time for a new M/C.
joe_padavano is offline
Old August 28th, 2018, 02:46 AM
shiftbyear's Avatar
If the way you bleed brakes works fine disregard this suggestion. Came across a method called reverse bleeding if you want to consider trying. Good luck.
https://www.brakebleeder.com/solutio.../how-it-works/
shiftbyear is offline
Old August 28th, 2018, 05:10 AM
rob1960's Avatar
If you suspect that brake fluid got in the booster I'd definitely pull it & check it. When I did the disc brake conversion on my '68 I was replacing the booster anyway but the old one had quite a bit of brake fluid in it. I don't think that brake fluid would hurt the rubber parts inside the booster but they're cheap enough I'd put a new one on along with the master.
rob1960 is offline
Old August 28th, 2018, 08:11 AM
Again, the M/C has to be replaced no matter what. Once you pull it off, it will be obvious whether or not there is fluid leaking out the back. The seal between the M/C and booster should prevent fluid from being sucked into the booster. Usually there is a wet trail down the outside of the booster under the back of the M/C when this happens.
Check the condition of this seal when the M/C is off.
As for the reverse bleeder systems, why in the world would you want to push old brake fluid contaminated with worn seals back into your new master cylinder. I've never been able to understand why that system makes any sense.
Old August 28th, 2018, 09:08 AM
dinanm3atl's Avatar
Copy. That was my plan. I looked at prices and even the nicest/best ones are not too much. With the simple system replacing in the garage should be quite easy...
Now if only I owned a single standard tool. A long time of BMW ownership means I just have a lot of metric and a bunch of 10mm and 13mm as they go missing...
Old August 28th, 2018, 09:13 AM
Not only do you need SAE tools for this job, you NEED a set of flare nut wrenches to avoid collateral damage.
Old August 28th, 2018, 03:53 PM
dinanm3atl's Avatar
Yah. I have that in Metric. Need to build up tools for an American car.
Old August 28th, 2018, 04:34 PM
Hookers under Hood
76olds's Avatar
The line wrenches Joe posted will certainly come in handy as you know . I spray the fittings with liquid wrench the day or two before I start wrenching on the brake lines, depending on corrosion. I hate twisting lines then having to replace them.
76olds is offline
Old August 28th, 2018, 06:27 PM
dragline's Avatar
Might as well flush the whole brake system while you're at it. Brake fluid absorbs moisture and causes rust, might be time to start fresh, the front hoses to the calipers can also deteriorate over time. Reverse bleeding works great, one man operation, best way to get rid of air.
dragline is offline
Old August 29th, 2018, 12:33 PM
dinanm3atl's Avatar
Yah. I'd do that for sure.
Of course. Definitely would bleed and replace all the fluid.
Old August 29th, 2018, 02:09 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Get chew one of these(see links). Quick...easy. I can do all 4 bleeders in 30 mins or less. Dont forget to get the correct master cylinder adapter. I see they have upgraded the pump hose with a quick-disconnect. Make sure the adapter comes with the mating male end. I have several adapters for each vehicle I own. I use small surgical hose(amazon) attached to the bleeders down into a cup to recover the waste fluid.
Always use the correct fluid. Make sure its fresh and of high quality. Never store the fluid in the motive pump. Store everything in a clean dry environment. Never use fluid thats been in an open container with fluctuating ambient conditions. It does absorb moisture just sitting in the container same for your brake system.
I bleed all of my vehicles brakes on a biennial or triennial basis regardless of miles. Thats why my 95 Jeep GC has its original calipers. Sure its soft lines have been replaced as those lines should be replaced every decade or so as a safety item.
How many people do this...only the few ****-retentives like myself..
Clean fresh fluid and clean tools equals a happy safe long lasting hydraulic brake system.
https://www.summitracing.com/parts/mvp-0106?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-motive-products&gclid=Cj0KCQjwiJncBRC1ARIsAOvG-a4tZFE0PcRCRzflW7kx2iOUF63_Zh9wfwlwyNogJ36dMwtkzEm aMggaAvW6EALw_wcB
https://www.jegs.com/i/Motive-Products/715/0090/10002/-1?CAWELAID=1710740688&CAGPSPN=pla&CAAGID=157690684 31&CATCI=pla-224363064311&CATARGETID=230006180037474793&cadevic e=c&jegspromo=thirdparty&gclid=Cj0KCQjwiJncBRC1ARI sAOvG-a54wAFrgRi9111uheX4JfEVwsRGwr2AwXihNYe20g32xjtsyES Yqw4aAp3fEALw_wcB
droldsmorland is offline
Old August 29th, 2018, 02:16 PM
I actually prefer the Vacula bleeder, same idea but it uses shop air to create a vacuum. I've never had to bleed more than one time, nor do I even have to bench bleed the master cylinder. This just sucks all the air right out of the system. Best tool I've ever bought.
Old August 29th, 2018, 03:31 PM
Thats a nice one Joe. What did they git ya for that unit?
Old August 29th, 2018, 03:35 PM
I got mine used at the Long Beach swap meet, probably 20 years ago. No one knew what it was - not even the seller. I paid $15.
Hookers under Hood
76olds's Avatar
Just looking at the "Swiss" made sticker sets me back too far haha.
76olds is offline
Old August 29th, 2018, 06:20 PM
Lsx442's Avatar
Do you have to do anything to prevent air getting around the bleeder screw?
Lsx442 is offline
Old August 30th, 2018, 08:09 AM
Air that leaks around the bleeder threads immediately gets sucked into the unit. Yeah, the fluid coming from the screw into the bleeder unit has air bubbles from this. Who cares? The air flows to the lowest pressure area, which is inside the unit. It can't physically flow upstream into the brake system.
Old August 30th, 2018, 08:20 AM
Lsx442's Avatar
Thanks Joe you kind of answered my next question. One last one - if air bubbles are still in the line, how do you know when you got all the air out of the brake system?
Lsx442 is offline
Old August 30th, 2018, 08:23 AM
I just run the bleeder until it sucks about 1/4 of the fluid out of the M/C reservoir, then go on to the next wheel. Probably more like 1/2 if the lines are empty or I want to completely flush the system. Actually, you can hear the difference in the sucking sound. The sound is different if there is a lot of air coming out vs. just the leakage around the bleeder screw.
Old August 30th, 2018, 04:27 PM
Hookers under Hood
76olds's Avatar
I need to get out to more swap meets! Burls creek is only spring and fall here in Ontario, not as good as it was years ago.
$15 bucks... , Oh, I bet you felt awful taking it off his hands for a steal eh haha!
76olds is offline
Old August 31st, 2018, 09:27 AM
dinanm3atl's Avatar
What is the 'correct' fluid for these cars?
Old August 31st, 2018, 04:56 PM
Lansing built
1970cs's Avatar
Dot 3
1970cs is offline
Old August 31st, 2018, 06:58 PM
I do a manual version with a mity vac. The screw leaks are little bubbles. Big bubbles in line are big tube width bubbles. They do a great job.
Koda is offline
Old September 1st, 2018, 08:55 AM
dinanm3atl's Avatar
Originally Posted by 1970cs
Dot 3
If you completely flush can you upgrade? DOT3 is kind of old school.
Old September 1st, 2018, 08:58 AM
I use DOT4 now in all my vehicles.
Old September 1st, 2018, 06:28 PM
dinanm3atl's Avatar
Me too. Or DOT5 in my track cars. I was asking basically if the difference in fluid is OK for the older vehicle. IE won't break stuff down or the viscosity is too low.
Old September 16th, 2018, 06:21 PM
dinanm3atl's Avatar
Fresh booster, master and bleed. Back on the road and feels great!
airborne1942
Brakes/Hydraulic Systems
June 4th, 2015 04:20 PM
timothypaul
41
February 12th, 2015 09:49 AM
J-(Chicago)
October 9th, 2008 08:12 AM
Deputy442
September 5th, 2008 05:15 PM
dynamic88
July 28th, 2007 08:04 PM
Quick Reply: 1970 Olds 442 Developed Mushy Brakes(Power Front Disc)
