Very Old Oldsmobile
Old April 30th, 2024, 01:58 PM
handyman2009's Avatar
Very Old Oldsmobile
Hello everyone, my friend has a very old Oldsmobile maybe a 1927 but not 100% sure that we would like to have as much info on as possible, it a Roadster with 2 spares in the front fenders and an extra seats that open in the back of the car and behind that with an old style moving trunk behind that. I can probable supply some pictures later on but for now I took the only picture of the build plate under the hood (attached). Thank you all for the help
Francis
handyman2009 is offline
Old April 30th, 2024, 02:53 PM
Francis, that would definitely be a cool Oldsmobile! I'm sure someone can give you some info off of the build plate. Make sure you post some more pictures.
Olds64 is offline
Old April 30th, 2024, 03:02 PM
With regards to year of manufacture, OLDS vehicles were produced w/ four wheel brakes beginning 12-8-1926, prior years they would be two wheel brakes. I can't say if during this period a four wheel vehicle produced after 12-8-1926, but within the calendar year 1926 would have been considered a 1927 model year or a 1926 model year - something to consider anyways. Does it have four wheel brakes or two wheel brakes?
Vintage Chief is offline
The car is in need of a full restore but according to him he has all the parts for it, found something that look a little like it on the web but not exactly... I will post some more pictures as soon as I go visit him again
1931/32 Olds F31/32
Old April 30th, 2024, 03:16 PM
For your reading pleasure/consideration. SOURCE: Setting The Pace: Oldsmobile's First 100 Years (Earley & Walkinshaw, 1996.
Old April 30th, 2024, 03:20 PM
oldoldss's Avatar
Without "Body by Fisher", and with a stamped, not embossed, plate I'd say a little earlier than 1927.
oldoldss is offline
Old April 30th, 2024, 03:24 PM
There exists some pertinent information for you to peruse in this thread - have a look. Note the call out of both engine number & chassis number. You can find additional useful information in this thread which might assist you moving forward.
1927 Oldsmobile sport coupe
Old April 30th, 2024, 03:27 PM
^^x2^^ I should look up when OLDS MOTOR WORKS stopped producing embossed tags located on the vehicles (if I can find it).
Old April 30th, 2024, 03:30 PM
Thanks something to look for next time I visit him
Old April 30th, 2024, 03:45 PM
GM purchased 60% of Fisher body in 1919 then in 1926 GM purchased Fisher Body in its entirety (integrated entirely as an in-house coachbuilding division of General Motors).
Old April 30th, 2024, 03:49 PM
That's probably why the job number is so low
Old April 30th, 2024, 04:08 PM
I don't know how to read the significance of either the JOB NO. or the BODY NO. I do know there was a time prior to GM's purchase of Fisher when data plates were labeled 'Fisher Body Works' as opposed to 'Body By Fisher'. Fisher stood alone for many years building bodies for numerous automobile manufacturers. I suspect 'Fisher Body Works' data plates were installed on most if not all motor vehicles prior to GM's purchase of Fisher in 1926 at which time 'Body By Fisher' was most likely subsumed into GM. Just a guess.
Old May 2nd, 2024, 12:23 PM
Here are more pictures of the car in question, hopefully these help identify the car... it needs lots of works for sure
Old May 2nd, 2024, 12:30 PM
She's a roller though!
Olds64 is offline
Old May 2nd, 2024, 01:58 PM
therobski's Avatar
Wow, that's really in great shape. Don't let "Full Custom Garage" on Motor Trend TV see it! That guy does amazing work with these cars...
therobski is offline
Old May 2nd, 2024, 03:04 PM
Proud Viet Nam Veteran
redoldsman's Avatar
A member of our club has a 27 Landau and it has wooden spoke wheels. Maybe both wooden and steel spoke wheels were available that year. I don't know.
redoldsman is offline
Old May 2nd, 2024, 03:45 PM
You bring up a good point. Through some modest research, the best I've come up with is the car belongs to the Oldsmobile Series F vehicles. I was keen to search/evaluate vehicles w/ the OP's wire spoke wheels, which appear original. I'd suggest the body style is almost certainly Series F. How that aligns w/ the absent Fisher Body Works, Fisher Body Division or Body By Fisher remains a mystery. Series F vehicles were 1st produced in 1928. Possible they continued to use the OLDS MOTOR WORKS JOB NO. BODY NO. tag post 1926 when GM purchased Fisher. Also, possible there exists an additional Fisher tag located elsewhere on the vehicle - it's almost implied to a certain degree with the express statement on the OLDS MOTOR WORKS tag "CORRESPONDENCE PERTAINING TO THE BODY MUST BEAR THESE NUMBERS". It was a time which saw GM & Fisher yielding to corporate merger so who knows.
Old May 2nd, 2024, 03:59 PM
I will keep looking but didn't see any other plaque so far... The engine is no help... I was hoping so, also notice the side of the hood those lovers don't move but in the grill I believe the can be adjusted
Also the owner keeps telling me it's a 1927... Maybe early prototype for the F Series, that would be cool... He ounce told me that he had the registration for it and that's why he keeps calling it a 1927.
Old May 2nd, 2024, 04:18 PM
The engine is certainly an in-line straight six but Oldsmobile produced a modest variety of these from 1923 - 1930? The body STYLE, from everything I've found, certainly resembles the Series F vehicles. I think this vehicle is a 2-door coupe (as opposed to a roadster) as witnessed by what appears to be a window frame?
Old May 2nd, 2024, 04:30 PM
No I believe it is a roaster the metal is the window frame and they are up and other pieces are from the convertible parts. Not sure if we can put the windows down to show it's true roadster with rubble seat and rear trunk. Is it possible they made one to show the public before starting production, to me it looks like very early versions of a F Series but that's why I am here as I am no expert just love the look of that car
Old May 2nd, 2024, 04:31 PM
What appears to me to be hallmark styles of the Series F vehicles. I think this (below) vehicle is the roadster. Many owners embellish wheels. None-the-less, appears to be similar louvers, same placement, same contours, etc.
Old May 2nd, 2024, 04:33 PM
Hell, I'm no expert on these massive pieces of metal. I'm learning as we go along, as well. Love the old school cars. I'm a big REO fire truck fan.
Old May 2nd, 2024, 05:02 PM
Coupled w/ the previous (above) image pertaining to production numbers here is the remainder of the Series F vehicles which may or may not come in handy. SOURCE: Setting The Pace: Oldsmobile's First 100 Years (Earley & Walkinshaw, 1996).
Old May 2nd, 2024, 05:07 PM
No I believe it is a roaster...
You can cook a roast in it? That's what that extra little door is for?
Old May 2nd, 2024, 05:26 PM
Stupid autocorrect... Lol I did saw one like you just posted but it doesn't have the spares in the front fenders and the trunk in the back... Guess those might have been options
Old May 3rd, 2024, 05:50 AM
Ancient Iron's Avatar
Car in question is a 1930 Olds. F series Convertible. The L series first appeared in 1932 with an eight-cylinder engine. Roadsters did not have roll up door glass, they would have side curtains.
As for the little door on the passenger side it is a golf bag door.
Ancient Iron is offline
Old May 3rd, 2024, 06:34 AM
That's great info so now we know it is a convertible and not a roadster but what about the firewall plaque that shouldn't exist on a 1930 car as by that time according to some they were all Fisher Body
Old May 3rd, 2024, 06:40 AM
See Post #17. It's highly likely nothing is carved in stone when you're acclimating a merger & acquisition. I'm still somewhat suspect there might exist an additional Fisher body tag somewhere on the vehicle?
Old May 3rd, 2024, 06:46 AM
The Fisher Body tag would be embossed like the other one I saw on the 1927 and so far I haven't seen anything like that, not saying it's not there but well hidden for now. I will keep looking and keep you all posted, thank you all for the help
Old May 3rd, 2024, 06:58 AM
I think we're getting closer. Attempting to validate this information I note there is no convertible listed for 1930 - at least by the name "convertible". The 1930 Series F (contained in the book) does list three convertibles; however, they're all identified as having the Viking V-8 and your image (above) demonstrates an in-line straight six banger. Scratching my head. Possible I missed something?
Old May 3rd, 2024, 05:41 PM
  #31
We looked everywhere this afternoon and didn't find any other tags. He is going to look for the paperwork for the car but last time he couldn't find them...
Old May 3rd, 2024, 05:46 PM
  #32
Too bad. I read a somewhat discordant thread on another forum where someone mentioned passenger side floor board. The thread was hard to follow.
Old May 3rd, 2024, 07:22 PM
  #33
Phantom Phixer
Charlie Jones's Avatar
I think I have come up with a pretty solid answer, courtesy of The Cars of Oldsmobile by Dennis Casteele (1981)
It is a 1928 Oldsmobile Deluxe Sport Roadster.
I know it is a 28 because I saw this;
In addition the discrepancy of the car supposedly being a '27 and it actually being a '28 could be explained by the fact that in the early days some states would title a car by the year that the car was first registered in.
Many 1928 model cars were produced in late 1927.
Now here is a pic of a '29 Deluxe Convertible Sport Roadster, but since 28's and '29's were almost the same it looks like a dead ringer for the car in the pics.
As for the question on wire wheels.
You could have either wire or wood wheels in '28.
And you could even get disc wheels.
Charlie Jones is offline
Old May 3rd, 2024, 07:33 PM
  #34
Phantom Phixer
BTW
That is a very rare car.
The spec sheets shown here by Vintage Chief shows a total production of 101.
Old May 3rd, 2024, 09:10 PM
  #35
And, Deluxe models came w/ 6 wheels...makes sense.
What do you make of these things? At first I thought they were to secure the spare wheels, but I couldn't find these devices on other Series F vehicles from any year; or, maybe I didn't look at enough pictures &/or they were hidden in the pictures. However, I'm not sure of their function. It appears a type of solid metal bar turnbuckle stile so-to-speak; almost as if you'd tighten or loosen each one for some reason - to manage the flex of the fender(s) with the wheels in place? Puzzling these things.
Old May 3rd, 2024, 09:31 PM
  #36
Still noteworthy is the cowl data plate tag - OLDS MOTOR WORKS BODY NO. JOB NO. with no mention of Fisher anywhere. When GM initially purchased 60% of Fisher body in 1919 I believe the contract stipulated something to the effect Fisher would retain exclusivity regarding branding & other related items for a period of 10 years. That might, in fact, suggest regardless of the chassis manufacturer, Fisher could elect to use whatever cowl data plate tag(s) they chose (at least up until 1929) - even though GM bought Fisher lock-stock & barrel in 1926. A unique cowl tag for sure since cowl tags were different among the other divisions of GM and other car manufacturers as well during the time period(s) Fisher stood on their own.
Old May 4th, 2024, 05:57 AM
  #37
Olds might have called it a "Roadster" even though in reality it is a convertible. There was a thread on C.O. about a 1936 Olds that was a two-door sedan and Olds advertised it as a "Five passenger coupe". Advertising and reality are sometimes two different things.
Old May 4th, 2024, 06:13 AM
  #38
Look at the dashboard of a 1928 Olds or a '29 for that matter. they are different than the 1930. Also, the car in question has solid bumpers where the .28-'29 cars had split bumpers. Shame the car was left to the elements like that along with the 1958 Ford retractable behind it.
Old May 4th, 2024, 03:47 PM
  #39
Phantom Phixer
the car in question has solid bumpers where the .28-'29 cars had split bumpers. .
The split bumper was not a year thing.
The split bumpers were on 5 wheel cars. (no side mounts)
The 6 wheel cars (dual side mounts) were equipped with solid rear bumpers.
Courtesy again of The Cars of Oldsmobile.
Old May 4th, 2024, 04:00 PM
  #40
What do you make of those thingamabobs (Post #35) on the front fenders?
Quick Reply: Very Old Oldsmobile
