Floor pan interchange/availability 68 Delta Custom
Old May 27th, 2019, 08:42 AM
ProFastAutoSolutions's Avatar
Hey All,
Im working on getting a 68 Delta Custom back on the road. My drivers floor pan is badly rusted and i need to change it but im not finding any direct fit aftermarket panels. is there anything that people have used that works, or anything close? Im assuming the cutlass pan is going to be to small, and the impala pan looks substantially different at the front. Any help would be great.
Thanx!
ProFastAutoSolutions is offline
Old May 27th, 2019, 09:20 AM
2blu442's Avatar
Do you need the entire floor pan? The reason I ask is I've got a 4 door floorpan that may have the same front third to half, but the back seat area is different. I could cut and ship the portion you need if this will help. I suspect there's not enough demand for the aftermarket to reproduce these. John
2blu442 is offline
Old May 27th, 2019, 11:36 AM
I really only need the drivers side. from where it seems in the door jamb to middle of the tunnel. and about 3ft long. IT seams at the front to the firewall right by the pedals, but im still awfully weak there. if i could get about 6" past the seam into the firewall, that would work. but if i gotta just do seam back i can fab the front part if needed.
my hump coming out of the floor pan into the drivers door jamb is all rotted out too. so i really gotta go to where the rocker seams onto the floor pan. all the way to the tunnel, and then back to the back of the drivers seat.
Old May 27th, 2019, 07:30 PM
Vistabrat72's Avatar
We sourced a driver's side floor pan for our 1966 Ninety-Eight LS sedan from the link given below. A mock fit so far shows trimming will be needed, the panel is claimed to fit 1965 - 1970 models. I am not sure if it would work with the 88 series, perhaps the more in the know folks could elaborate on this. There is a decent amount on this part to possible fix past the toe board seam as you mention, but would need more metal fabrication to reach the door post area. If yours is rusted as bad as said, the offer from 2blu442 may be the way to go, just thought I would give another possibility. Fixing up an Oldsmobile is fun, the large models make it even more so tracing and fabricating needed parts. http://www.c2cfabrication.com/collec...mobile+98+1966
Vistabrat72 is offline
Old January 17th, 2024, 08:30 AM
Oldekc's Avatar
Hello, how did you manage to solve this problem? I'm also looking for floor panels for my '68 Delta Custom
Oldekc is offline
Old January 18th, 2024, 02:23 PM
Love1955oldsmobile's Avatar
Buick la sabre should fit.
Ron
Love1955oldsmobile is offline
Old January 18th, 2024, 05:05 PM
Ron
This post is from 2019. I hope the OP found a floor pan.
I doubt there are any aftermarket floor pans for that either. In any case, Impala will be close enough to make it work. Those are available as repros.
joe_padavano is offline
Old January 18th, 2024, 08:23 PM
Oldekc's Avatar
Thank you for the information, I hope I will be able to repair my Delta quickly
Oldekc is offline
Old January 19th, 2024, 02:24 AM
Tri-Carb's Avatar
Just a lead. Investigate these:
Buick Electra Parts Floor Pan | Classic 2 Current Fabrication (c2cfabrication.com)
Tri-Carb is offline
Old January 19th, 2024, 11:06 AM
2blu442's Avatar
I sold the OP a portion of my 1970 Delta 88 floorpan in 2019. I don't remember hearing back from him if he was able to make it work on his 1968. John
2blu442 is offline
Old January 20th, 2024, 12:07 AM
OLDSter Ralph's Avatar
Originally Posted by Tri-Carb
Tri-Carb, THANKS for the lead. Their catalog show floor pans for a couple of my older Olds projects. I'll call them next week.
OLDSter Ralph is offline
Old January 20th, 2024, 05:02 AM
Tri-Carb's Avatar
Sure thing Ralph.
Perhaps this is the pan:
SKU: 730-440-1
1965-1970 Oldsmobile Delta 88 Front Floor Pan, LH
$ 149.99
Tri-Carb is offline
Mossy
Body work
17
April 2nd, 2020 04:35 AM
F-85 4-4-2
August 26th, 2014 09:37 AM
dads72
Body work
July 27th, 2014 07:43 PM
Bfg
July 18th, 2014 08:11 PM
jasonjtrahan
September 18th, 2007 09:54 PM
Quick Reply: Floor pan interchange/availability 68 Delta Custom
