1967 Delta 88 Super Rocket?
Old March 29th, 2006, 09:57 PM
'67 Delta's Avatar
Can someone tell me about this car? I own a Super Rocket what is that, what makes it so special? Can someone help me out? By the way what were the engine sizes that Oldsmobile came up with? The Oldsmobile that I have is a 2 dr hard top 4 Barrel Carbutor.
'67 Delta is offline
Old March 30th, 2006, 04:40 AM
Past Administrator
Oldsguy's Avatar
Well, most Oldsmobiles are known as "Rockets" since Oldsmobile built their first overhead valve V8 in 1948, or maybe shortly thereafter. They came up with an identity campaign which has worked well for so many years. The engines were dubbed "Rocket V8s" with the popularity of jet engine airplanes and the interest with space men, etc. starting in the early fifties. It has been a nickname for Oldmobiles since. I think you get Super Rocket from the air cleaner cover, right? I might be wrong on that. They started making engines with higher compression ratios and I have seen "Ultra High Compression" decals on the air cleaner covers as well. In 1967 I think the big block was the 425 ci engine. Prior to that the sizes were 330 ci and 394 ci. About 1968 they started building the 350 ci and 455ci. I hope TexasRed sees this post and responds because he is more up to speed with Oldsmobile history. At any rate, welcome to the site and here's to your Oldsmobile, tell us more about it.
Oldsguy is offline
Old March 30th, 2006, 03:17 PM
Oldsmaniac's Avatar
Olds first real V-8 engine came about in 1949...It was called a Rocket. It came in various displacements as already mentioned until 1964 when the modern Rocket engine was put into production. This displaced 330 cubes. In 1965 the big brother to the 330 was produced with 425 cubes. Olds titled this new top of the line V-8 the Super Rocket to state the fact that it was new and improved. While the big block was called the Super Rocket the smallblock 330 was called the Jetfire....Yes, these terms were on the Air Cleaner but also in sales brochures etc. 1967 was the last year for the 425 as in 1968 the displacement went to 455 and the 330 was increased to 350 cubes. The 67 88 with a 425 and 4bbl is no slouch.....Good Luck!
Oldsmaniac is offline
Old March 30th, 2006, 09:19 PM
jdorour's Avatar
The other guys are correct.
The Original Olds engine designs:
303CID = Rocket
324CID = Rocket
371CID = Golden Rocket
394CID = Rocket, Sky Rocket and Super Rocket
The 1961 - 1963 F85 V8:
215CID = Rockette
215CID Turbo = Jetfire or TurboRockette
The second Gen Olds V8:
260CID =
307CID =
330CID = Jetfire, Cutlass, 442 Rocket (1964 only)
350CID = Rocket
400CID = 442 Rocket
403CID =
425CID = Super Rocket, Starfire (370 and 375 HP only), Toronado Rocket
455CID = Super Rocket, Rocket
Oldsmobile came up with the names only as a marketing gimic.
Chevy used TurboFire and TurboThrust, Buick used Wildcat and so on.
jdorour is offline
Old May 3rd, 2006, 06:19 PM
J'ville's Avatar
A lot of people think the 425 is actually the best engine Olds built. It just never made it into a 442 or Hurst Olds, so never got the credit it should.
It was a square (bore and stroke same or close too) engine that had a lot of rev potential. The 455, although powerful, was a stroker and could not rev like the 425.
J'ville is offline
Mak
53
November 18th, 2011 04:23 PM
Affinity
April 20th, 2010 05:35 AM
dlv4540
March 14th, 2010 05:38 AM
<425superrocket>
October 14th, 2004 08:18 PM
Paula
August 10th, 2003 10:22 PM
Quick Reply: 1967 Delta 88 Super Rocket?
