Click Here
Help! Tires rubbing on chassis
Old Aug 8, 2013 | 04:45 PM
Zandernucci's Avatar
Hi I'm a newbie! I just picked up a 86 olds supreme brougham. I picked up a set of 20 inch Irocs 255/35. An the rear rubs on the chassis just hardly but it seems like the tire is too wide. An the front rubs a little bit when I'm fully locked In a turn. I need some suggestions.
Old Aug 8, 2013 | 10:01 PM
Wheel spacers?
http://www.bing.com/images/results.a...&sp=1&qs=IM&sk=
Old Aug 8, 2013 | 11:34 PM
They want like 300 bucks at town an country for parts an labor.
Old Aug 9, 2013 | 01:33 AM
nsnarsk65cutlass's Avatar
Smaller tires rims.
Old Aug 9, 2013 | 02:50 AM
Yeah, maybe you should use the right size tires.
Old Aug 9, 2013 | 04:52 AM
s i 442's Avatar
Oldsmobile enthusiast
Wheel spacers are about $30 to $70 a set on Ebay, depending on size.
Or grab a side grinder and look for the rub spot and start smoothing out.
Old Aug 9, 2013 | 06:39 AM
How about you tell us what is the offset and width of the rims? Sounds like these have too much positive offset.
Old Aug 9, 2013 | 07:24 AM
brown7373's Avatar
There is a limit to how much larger wheel/tire combo you can use. Spacers may work, but then the tires may rub the fenders. Also, be careful when the front wheels are turned and you go over a bump, like in or out of a driveway. That is when the suspension will move and the tire will likely rub and bend the top of the weelwell and fender.
Old Aug 9, 2013 | 08:11 AM
The 255/35-20s that the OP is using are within a tenth of an inch of the dimensions of 255/60-15s. While I'm not personally a fan of 20" wheels, his selection actually is well thought out and makes sense for this car. I've got money on the wrong wheel offset being the problem. The tire size should NOT be a problem for this car.
Old Aug 9, 2013 | 09:55 AM
Old Aug 9, 2013 | 09:56 AM
Sorry but I'm new to this stuff. How do I find the positive offset an width ?
Old Aug 9, 2013 | 11:31 AM
Old Aug 9, 2013 | 12:42 PM
Old Aug 9, 2013 | 12:50 PM
Old Aug 9, 2013 | 12:58 PM
Old Aug 9, 2013 | 02:36 PM
s i 442's Avatar
There you go, figure all that into your rim/tire combo!!!!!LOL
Old Aug 9, 2013 | 04:32 PM
All of those wheel spec's are probably available on the manufacturers website.
Old Aug 9, 2013 | 06:36 PM
I'm just surprised that someone who spent good money to put wheels on his car that are a very different size than the originals were wouldn't know their basic dimensions.
Old Aug 9, 2013 | 07:12 PM
I deal with my local discount tire, they let me experiment with a few sizes, nice folks.
kanek4
Wheels and Tires
Oct 10, 2014 04:44 AM
crjeeper
Apr 13, 2011 07:45 AM
suppressivefire
Nov 24, 2009 05:48 AM
import extermination
May 17, 2009 11:07 AM
New'n72
Oct 3, 2007 02:36 AM
