kickdown electrics needed?
Old Mar 23, 2010 | 06:28 PM
1964F85's Avatar
Hi,
I am about to remove the factory cast iron 2 barrel manifold to replace with a 77 350 4 barrel intake. I see the newer intake does not have the provision for the mounting of the electric kickdown rod/switch . Is this really needed to function, as I have no problem just manually downshifting, if I really need to, by hand. I noticed there was an additional microswitch/pushbutton that was also unhooked and just laying on top of the intake. I'd guess the microswitch was for the switch pitch operation. I'm willing to simply install a "power/economy" switch inside, like you'd see on an old late 80's jeep cherokee. Any ideas? I seen several other posts here regarding this question, but no real answers. Cheers, Mike
Old Mar 23, 2010 | 09:20 PM
drec02's Avatar
Try using a Summit universal kickdown bracket and the B&M TH-400 electric kickdown swith. Not sure if you are, but if you're running a TH-350 you won't need the set-up.
Uncle Hulka
Apr 23, 2014 05:00 AM
stocki26
Dec 27, 2012 08:27 AM
buzz lightyear
Jan 24, 2012 06:42 PM
bigbrother
Jun 18, 2007 12:34 PM
