fitting size
fitting size
Sep 16, 2010 | 09:34 PM
1973olds98
Jun 2009
fitting size
What size is the flare fittings for the transmission cooling lines. 73 olds 98 With a th400 thanks
10:45 AM
1973olds98
Find More Posts by 1973olds98
Sep 17, 2010 | 04:25 AM
507OLDS
Oct 2009
Erie,PA
If you are talking about the fittings for the transmission case,those a a british thread size.I've had to order those before.
507OLDS
Find More Posts by 507OLDS
Sep 17, 2010 | 10:46 AM
1973olds98
Jun 2009
A british size,,,,thats strange
1973olds98
Rear brake line fitting size?
yamahondarider
07:34 PM
1972 cutlass...wheel size fitting help...
CutlassS1972
06:19 AM
power steering fitting size?
EightyEightCut
10:20 AM
Brass vacuum fitting size?
defiant1
10:07 AM
Fitting 455 in 1955 Olds 98
Olds Nut
07:10 AM
Throttle Switch
01:43 AM
