Cable Needed on Conversion to 2004r
Old Apr 12, 2011 | 07:16 PM
Flye's Avatar
67 442, console shift
just put 2004r in (from TH400)
Shifter Cable (NOT THE TV cable) seems too short, and it won't pull back into the 1 position. And I believe the link at trans is 'rigged' at this point.
I've done numerous searches and am not having a lot of luck on someone that supplies a longer cable.
I was operating under the impression that the cable would be same, but should I be looking for a different cable to connect the 2004r?
Thanks,
Old Apr 13, 2011 | 05:45 PM
dhoff's Avatar
Try Shiftworks.com
Old Apr 13, 2011 | 09:37 PM
Aceshigh's Avatar
So it will shift in every gear properly except manual low gear??
Just curious because I am considering not bothering with the shiftworks kit.
I will just keep mine in drive if it works just fine and save the $150+ if that's all I'm missing.
Old Apr 14, 2011 | 09:54 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
A th400 is a 3 speed, and the 2004r is a 4 speed, ......so wouldn't you need another shifter with an extra notch?
Cables are pretty universal, you just have to have the angles right so they don't bind going through the motions.
Old Apr 25, 2011 | 05:16 AM
Flye's Avatar
The issue was more on the pan bracket and the lever on the trans more than cable length. It is now OK. Thanks,
jonstringer
Jun 3, 2010 09:36 PM
68conv455
Oct 9, 2009 06:49 PM
TedH
Jan 23, 2009 07:42 AM
Edveen
Feb 28, 2007 11:12 AM
kjones6039
Jul 7, 2006 06:44 AM
