Project 350 build/It's finally done
Old May 11, 2018 | 04:39 PM
cutlassefi's Avatar
Instead of burying this on the back page of the original thread, I thought I'd start a new one.
I mentioned this a long time ago, I was going to do a build on my own with the parts and pieces I've recommended over the years, along with the new piston from Mahle.
Well it's done, here are the final specs;
350 gas block bored to 4.100
Square decked to 9.315
Align honed with ARP bolts
N crank, .010/.020
Stock Rods
QF Slayer 750 carb
RPM intake, untouched
Erson TQ40 cam (what else right!)
7a heads with 2.00/1.62 valves, very minor bowl cleanup.
Dividers welded, crossovers filled
Mahle 10cc piston, 9.4:1 compression
Cloyes 9 keyway double row chain set
Stock Pan
Stock pump with purple spring
Valvoline VR1 10W-30
Run on 89 octane
Here are the dyno sheets. Is there any question why I'm such a huge fan of the Slayer carb? 1 jet change, 1 air bleed change and look at the fuel curve, perfect. Try that with a Qjet, or anything else for $325.00 for that matter.
File Type: txt
Project 350 dyno sheets.txt (8 Bytes, 98 views)
Old May 11, 2018 | 04:46 PM
cutlassefi's Avatar
Sorry, didn't attach correctly.
Old May 11, 2018 | 05:23 PM
I'm not able to see the text on those - it's too small.
Old May 11, 2018 | 06:16 PM
cutlassefi's Avatar
I'll try to attach another photo later, but it made 416hp and 418tq.
Old May 11, 2018 | 07:38 PM
coppercutlass's Avatar
Chevy budget Olds powered
Very nice.
Old May 12, 2018 | 07:20 AM
oldsmobiledave's Avatar
dyno sheets
Good Job Mark.
Attached are the dyno sheets rotated for easier reading. Still difficult to read when enlarged.
Enlarging the photo I think I read (correct me if I am not reading that right).
416.3 hp @ 5800 and 418.2 TQ @ 4500
I would like to see the same build but with the 4.00" crank in place of 3.385" stock crank. it would be very interesting to see the HP & TQ gains from the increased stroke.
Old May 12, 2018 | 07:26 AM
cutlassefi's Avatar
Yes and thank you.
Mike’s 422 build was essentially the same as this, except his had a little less camshaft and compression.
Old May 17, 2018 | 05:33 AM
JohnnyBs68S's Avatar
Just to clarify (I didn't see this mentioned here), this engine used the stock crank / stroke?
Reason I ask is that I'm looking at a rebuild on my 350 in the next few years and have been following cutlassefi's development of the new rod/piston/crank combinations, and as a result am getting really encouraged that I will be able to shoot higher than my original ~400HP goal without getting crazy w/ the compression ratio. 416HP w/ only 9.4:1 CR seems pretty impressive to me. I too would be interested in seeing what the increased stroke crank does to these power numbers.
Exciting times for SBO owners!
Old May 17, 2018 | 10:52 AM
cutlassefi's Avatar
It’s mentioned, stock N crank and rods.
The heads are the limiting factor here. The stroker build made way more tq but a little less hp because it had less compression, less camshaft and heads that weren't quite as good, although still not great. Hope this helps.
sjcrft
Oct 10, 2012 10:32 AM
cutlassjoe
Sep 19, 2011 09:23 AM
thatguy32567
Mar 10, 2010 04:34 AM
frostbyte
Jan 30, 2008 02:08 AM
