voltage regulator
voltage regulator
is there anything special about swaping out a voltage regulator in a 72 cutlass supreme. do i need to disconnect the battery and then just swap it out fot the new one?
oldman72
oldman72
voltage regulator
thanks for the info but before i buy a new voltage regulator. this is why i think its the problem. the lights, radio and fan kind of dim once in a while. they dont shut off just kind of go soft. its not all the time, just on occasion. the battery and alternator are both new.
oldman 72
oldman 72
Try checking all your connections and grounds. Unplug the regulator and plug it back in. Make sure all your connections are clean and tight. It could be regulator but I don't really think so. Is the alternator new or rebuilt? Just because it is rebuilt doesn't mean it is good. Of course if you replaced it and it did not fix the problem, it is probably okay. Good luck.
If all else is good in your electrical system, a new regulator is one more potential problem eliminated. The new ones are electronic and are supposed to be more reliable. I put new ones in both of my vintage vehicles and solved a bunch of problems, including the headlights brightening and dimming with engine rpm's. A bit costly ( around $80) but worth it in my opinion.
Chumley
Chumley
delta_88_germany
Feb 22, 2014 01:48 PM
