Torque Plating Question
Old Oct 16, 2009 | 10:38 AM
78cutlass's Avatar
78cutlass
I hear torque plate boring/honing is MANDATORY when rebuilding Olds V8s, especially SBO 350s & 403s. It makes sense, but has anyone skipped this procedure, and still produced a healthy engine that's held up over time without any significant issues that might be attributed to skipping torque plating? Your input is appreciated. Thank you.
Old Oct 16, 2009 | 05:15 PM
Bobsw32's Avatar
BobsW32
Yes I have skipped it but given the choice you should.....I have a torque plate that you can use if you or your machinist doesn't have one.
Old Oct 16, 2009 | 07:35 PM
cutlassefi's Avatar
Torque plate
And I have a Bor-Tru plate that will locate the bores correctly if you're taking enough out. A torque plate won't do that.
Old Oct 17, 2009 | 02:45 PM
78cutlass's Avatar
78cutlass
thank's guys, just trying to get into the meat/potatoes of diserable machine work for an Olds V8.
Old Oct 18, 2009 | 05:11 PM
380 Racer's Avatar
In my humble opinion you don't need to use a torque plate untill you get into the ultra high performance builds. I wound up buying one myself about 3 builds ago. Before that never used one. I would worry much more about a big block over a small block.
Old Oct 18, 2009 | 05:39 PM
78cutlass's Avatar
78cutlass
380Racer,
Yeah, that's what my engine guy said, and he's been building motors for 30-years or so. He basically said the same thing, that the torque plating is more for serious race build-ups. He built me a '69 Olds 355 with forged Speed Pros, 9.8:1 CR, which he claims will make about 350 HP/400 TQ all day long, and live forever without having been torque plated. However, the motor was treated to other diserable machine work. I'm still in the midst of having it installed in a '78 Cutlass.
Old Oct 18, 2009 | 05:44 PM
78cutlass's Avatar
78cutlass
380Racer,
By the way, that's a mean-*** SBO you put together...
Old Oct 20, 2009 | 04:00 PM
380 Racer's Avatar
Originally Posted by 78cutlass
380Racer,
Thanks!! I am very pleased with it so far .
hinz57
Jul 1, 2019 02:53 PM
mscott
Jan 28, 2011 11:23 AM
gearheads78
Jan 27, 2009 01:09 PM
Chaney3000
Mar 5, 2008 08:36 AM
mr-tom
Mar 16, 2007 09:28 PM
