Timing mark jumping around
I was trying to set the timing on my 307 in my 84 regency. I jumpered the Aldl and when I put the light on it the timing mark jumps around between 16 and 20 degrees before tdc
its idling rough and lacking power so that’s why I decided to check the timing
does this indicate my timing set is getting worn out?
Does the emission label say to jumper the ALDL to set timing? It's been a long time but I recall some vehicles required disconnecting the four wire connector at the distributor vs. jumping the ALDL. Someone that knows for certain please jump in to confirm.
