Timing chain slack
Old Dec 15, 2020 | 08:06 AM
Skydog9's Avatar
Skydog9
Timing chain slack
I want to check for timing chain slack. The largest socket I have is a 1 inch. I have the stock 350 motor. Can you tell me what size socket I'll need for the crank pulley?
And will I be able to turn it over with a breaker bar without pulling the plugs?
Old Dec 15, 2020 | 08:57 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You need a 1 1/8" socket.
Old Dec 15, 2020 | 09:18 AM
Sugar Bear's Avatar
Will not need to remove plugs, it will turn easily with a breaker bar. With good access one can often move the balancer back and forth by hand to check timing chain slack.
Good luck!!!
Old Dec 15, 2020 | 09:44 AM
Skydog9's Avatar
Skydog9
Thanks for the info.
Old Dec 15, 2020 | 12:51 PM
Skydog9's Avatar
Skydog9
Ok I've got a 1 1/8 deep socket with a 25 inch breaker bar. Sugar Bear you mentioned having good access. My motor is installed with nothing removed and I'm having a hell of a time getting onto the crank bolt. I got the socket on without being attached to the breaker bar, but with the socket on the bar, I'm not able to get onto the bolt.
Old Dec 15, 2020 | 01:09 PM
Skydog9's Avatar
Skydog9
I have not tried from underneath. But that won't work either for what I'm trying to do. I want to rotate the crank to TDC and check my rotor, and then rotate CCW until the rotor moves to check for timing chain slack. If I go from underneath I don't have someone on top to watch the rotor
Old Dec 15, 2020 | 01:22 PM
Skydog9's Avatar
Skydog9
Good idea
Old Dec 15, 2020 | 01:24 PM
I use my 1" Grey bar, 3" extension and socket. You will need a short extension to turn it from up top.
Old Dec 15, 2020 | 01:35 PM
Sugar Bear's Avatar
Can you grab the crank pulley by hand and rock it back and forth?
Old Dec 15, 2020 | 06:04 PM
Skydog9's Avatar
Skydog9
I can't budge it
Old Dec 15, 2020 | 06:40 PM
Skydog9's Avatar
Skydog9
No, it's an automatic
Amarion58
Jun 7, 2017 04:04 PM
at3regency
Jul 12, 2015 06:08 PM
tgilligan
May 8, 2013 03:54 PM
nonhog
Feb 18, 2012 07:02 PM
85ttop442
Feb 4, 2011 07:34 AM
