Stock compression ratio
Old Jun 3, 2010 | 05:22 AM
defiant1's Avatar
What is the stock compression ratio on a SBO? I have read plenty of articles about rebuilt motors achieving a different CR but have not seen what it is from the factory.
And while on the topic, does the compression ratio change dramatically on an older motor (over 100,000 miles)?
d1
Old Jun 3, 2010 | 09:44 AM
svnt442's Avatar
Don't get hung up on the mileage. The care that has been bestowed on an engine over it's lifetime will have a much greater effect on it that the odometer.
The compression ratio varied from about 7.8:1 to 10.5:1 and most anything else in between so just asking "what's the compression ration on a SBO" is a vague question. what year and what size engine? Did it come with a 2 or 4 bbl carb? What did it come out of? It all plays into how the engine was set up at the factory.
Old Jun 3, 2010 | 10:17 AM
defiant1's Avatar
Good point. Motor is a 350 with factory 2BBL out of a 1970 Cutlass Holiday Coupe.
Old Jun 3, 2010 | 11:57 AM
svnt442's Avatar
That will be a 9.0:1 ratio.
Old Jun 3, 2010 | 12:06 PM
defiant1's Avatar
Thank you, sir.
Old Jun 5, 2010 | 03:10 PM
nuttkaze's Avatar
What about the compression ration on a 1971 Cutlass Vert with a 4-barrel 350 single exhaust..
Old Jun 5, 2010 | 05:46 PM
cutlassefi's Avatar
Advertised is 8.5:1, but if you take it apart and measure everything I'll bet it's closer to about 8.0:1. I did it on 3 72's, they were all right about 8.1:1.
greenslade
Mar 29, 2011 03:56 PM
captjim
Sep 23, 2008 05:21 AM
BlueBlock350
Apr 7, 2008 11:22 AM
OLD SKL 69
Jan 22, 2008 08:11 PM
Escalus2k4
Jan 15, 2008 08:29 PM
