PCV Grommet
Old Oct 6, 2016 | 09:23 PM
77ricbaez's Avatar
PCV Grommet
just curious what would happen if parts of the grommet were to crumble inside the hole.
Old Oct 6, 2016 | 09:37 PM
If they are big chunks they will block oil return holes at the ends of the heads. Tiny peices will wind up in the pan eventually.
Old Oct 6, 2016 | 09:44 PM
77ricbaez's Avatar
So in other words, I'd be screwed? I read online that the pieces wouldn't affect the engine and would probably be obliterated.
Old Oct 6, 2016 | 10:51 PM
77ricbaez's Avatar
Wait, the stock valve covers have a baffle which means that it would catch any broken pieces. Right?
Old Oct 7, 2016 | 04:11 AM
If they block return holes then the oil has trouble draining back into the pan. They will not harm moving parts of the engine.
Possibly
Old Oct 7, 2016 | 04:51 AM
I wouldn't worry about it. They'll probably just sit in the baffle forever.
You could always remove the valve cover and blow them out with compressed air.
Old Oct 7, 2016 | 07:52 AM
77ricbaez's Avatar
Alright sounds good. I'll try to get that rock hard grommet out haha. If it falls in I probably won't get it out, or I'll try to use a vacuum to get the pieces, either way it's in the baffle.
Old Oct 7, 2016 | 07:57 AM
Oh. They're not in there yet?
Just cut the grommet apart and pull the pieces out with needlenose pliers.
Old Oct 7, 2016 | 10:20 AM
frankr442's Avatar
Just take the valve cover off. If the grommet is that old and hard, it could probably use a good cleaning inside.
Old Oct 13, 2016 | 07:41 PM
77ricbaez's Avatar
Ah. Any tips on making this a lot easier? WD-40? Heating the grommet with a hair drier? It's putting up a good fight Lol. I dont want to destroy it too much to the point where it will take longer to get the pieces out than to just replace the stupid thing
Old Oct 16, 2016 | 08:13 AM
jpc647's Avatar
It'd just take the valve cover off. I did it right before an oil change and I used a little bit of soapy water to get mine to go in. When they are hard they can be a real PITA. You may be better of using a sharp razor to cut it into 2 or 4 pieces and pulling those out. IF a big piece falls you'll be able to get it out with needle nose pliers.
Old Oct 16, 2016 | 09:45 PM
77ricbaez's Avatar
I already got it out, it wasn't as bad, pretty much had to stick a flat head in to break it apart. It helps that the baffle was quite small which meant that any fallen pieces could be reached with your fingers
Old Oct 17, 2016 | 04:50 AM
jpc647's Avatar
Glad it worked out for you.
tinner
Jun 9, 2013 05:47 PM
Stumpy
Nov 13, 2011 06:17 AM
jpc647
Nov 11, 2011 12:58 PM
panos
Aug 29, 2010 08:53 AM
csouth
Jun 11, 2009 06:57 AM
