Mini starter making screeching sound in gear
Old Jul 29, 2018 | 08:56 AM
AR15's Avatar
My stock starter went out and having headers it was so tight getting a new one back in.. so I bought a powermaster mini starter. Now when I put it into drive and rev the engine it makes a screeching sound. It sounds like maybe the starter is rubbing against the flex plate. I checked the bolts and the flexplate is tight
The starter isnt in a bind against anything pushing it at a weird angle. I've tried it in three or four different positions.. I've tried it with shims and without.. same issue every time. Anyone have any ideas?
edit: Car is a 71 Cutlass S.. with 350 motor.
Old Jul 29, 2018 | 02:25 PM
Have you installed the shim that goes between the starter motor and the mounting base?
This is for illustration purposes, you need the one for your starter.
https://www.summitracing.com/parts/pwm-624
Old Jul 29, 2018 | 03:07 PM
AR15's Avatar
No, I've didnt have that in the box. I installed the one that goes between the mounting base and the motor. This circular one is what I need? Thanks for the reply.
Old Jul 29, 2018 | 03:30 PM
Probably what starter pn are you using?
Old Jul 29, 2018 | 04:15 PM
Firewalker's Avatar
Yep, you need a spacer to gain the right distance. I had the same problem with the powermaster. The starter teeth need to move back, to get clearance away from the flywheel ring. It's different from a normal starter shim that moves them down.
Old Jul 29, 2018 | 04:23 PM
AR15's Avatar
PN is 713-9610.
yup, that's exactly what I need. Thanks so much guys, appreciate your help. I'll post back if it works for anyone having the issue in the future.
Old Jul 29, 2018 | 04:43 PM
Firewalker's Avatar
Btw, in an emergency pinch, if you have some thick solder about the same thickness as their spacer or a tad more, you can cut the right length of solder off, to space it out and go around and that worked for me, on my 455. These go between the aluminum adapter block and the starter itself, then bolt them back together, and then bolt back onto the engines. Hot Rod ingenuity.
Old Jul 29, 2018 | 06:44 PM
PN is 713-9610.
That should be the one for your starter, call Powermaster to confirm. There should have been one in the box.
Old Jul 29, 2018 | 07:03 PM
AR15's Avatar
Ok, I'll call tomorrow. Maybe they'll send me once, it definitely wasnt in the box. I just double checked.
Old Jul 29, 2018 | 07:08 PM
Firewalker's Avatar
Mine was bought a few years ago from them and didn't have a spacer back then either. In fact what they sold was not a spacer washer but a spacer plate, if I remember right, and cost extra if you needed one.
Old Jul 29, 2018 | 09:21 PM
I bought one 2 years ago and it had a spacer. Its in the instructions.
Old Jul 30, 2018 | 05:51 AM
RandyS's Avatar
I bought one less than a year ago and it came with the spacer also.
Old Jul 30, 2018 | 05:56 AM
Firewalker's Avatar
Read the Olds boards further back, and you see none had them, except as an option.
Old Jul 30, 2018 | 07:47 AM
RandyS's Avatar
Not sayin they did, only what mine came with......
Old Jul 30, 2018 | 08:22 AM
Firewalker's Avatar
Wink
I understood, and I am glad it did
gtaa9
Jul 16, 2015 11:24 AM
timothypaul
Aug 2, 2013 07:40 AM
88hurstolds
Jan 11, 2013 07:43 AM
henryk8398
Ninety-Eight
27
Dec 13, 2012 04:32 AM
veltboy618
Jan 26, 2009 04:03 AM
