intake swap
intake swap
i have a 350 rocket from a 70 convert in my 70 supreme, as far as i know, it has less then 20000 miles on it, heres then thing, carb is beyond bad......i know nothing avbout carbs, so a rebuild is out of the question, a friend of mine offered to give an aluminum intake and a elsebrook four barrel. am i in danger of snapping rings or other castrophes with this swap, ive heard many horror stories about this.
super simple, unbolt the carb and anything attached to it, throw it out. Unbolt all the bolts that run into your intake ONLY. pop the intake off. clean all your mating surfaces, and glue the new intake on. Before you do this, make sure to drain some of your coolant, otherwise antifreeze will end up in your oil. Just be careful and take your time. It would be wise to find a chilton, it will give you the proper torque specs, and pattern, however someone on here can probably tell you too. LOL
Im not gonna say thats not true, but I have never heard that anywhere, as a matter of fact intake and manifold swaps are very popular, i have done numerous, never had any problems. Your not doing anything but allowing your engine to intake fuel and air more efficiently.
I'm not going to say it either. Instead, I'll say "what a load of BS". Swap the intake, you'll be fine. Of course, the qualifier is the old "when driven the same". Don't put on the 4bbl and start doing 8,000 RPM holeshots. That WILL break something (which, I suspect, is how these wive's tails get started). Also, be sure the new carb is jetted correctly for your motor. Too lean a mixture and you will break something.
Let's get serious here. A 350 cubic inch engine with 100% volumetric efficiency (which is optimistic) will flow just a hair over 600 CFM at 6,000 RPM.
Yeah, I'd say an 850 is too much. Keep in mind that GM tuned the Qjet to a wide variety of displacements by using the tiny primary bores for good low-end response and tailoring the air valve opening rate and angle to match the engine's requirements. I doubt your perfomer 850 will be able to do that.
i dont really subscribe to the more is better, im more of a free is pretty good kinda guy. ill look for a 500 or 600 , someone has to have laying around up here somewhere, plenty of donor fords quietly rusting away
You never said...Is it already a quadrajet? Thats the only way you have an Edelbrock 850
800 is the biggest they ever made a square bore carb
http://www.edelbrock.com/automotive_...erformer.shtml
In the 90's they bought the tooling from Q-jet and were selling them new with a few choices in CFM
like i said, i know less then nothing about carbs, im pretty sure he said eldebrook 850, but obviously it is not, either way i think ill pick up a smaller one. there a prefered carb with electric vs cable choke? the choke has never worked on this car and it will always start so i never really gave it much thought
To tell if it is look underneath the carb. If you have two very small barrels and two giant ones you have a Q-jet. If they look the same on all 4 then it is a AFB type. Get the number stamped on it and someone here can tell you what the CFM is. Maybe you will be lucky and its a 1405 or 1406 which is 600 cfm with and without electric choke.
intake
well, my intake showed up, it most definatly is not for an olds 350 to narrow, but its wider then a chebbys intake would be... maybe a ford or a pontiac?
neways i guess ill get one on e bay, but has anybody here ran a demon carb? been told they are pretty reliable and cheap
My combo is an Edelbrock Performer manifold with a Holley 600 square bore with a manual choke. It suits me fine, but thats my opinion. Some of the guys on this board use Holleys for doorstops..., I myself, don't have alot of Q'jet knowledge, but with the price of gas, I'm becoming kinda quadracurious.. LOL.
AND HERE IS THE WEBSITE THAT I HAVE BEEN LOOKING AT FOR A CARB SWAP
http://www.carburetorsandmore.com/index.htm
Four barrel carbs for the most part come in two flavors, square bore and spread bore. The square bore uses four barrels that are about the same diameter. The spread bore uses tiny primary bores for good atomization and gas mileage and two huge secondary bores for power. Most aftermarket four barrel carbs are square bore. The Qjet is a spread bore. That's why the intake manifolds are different.
svnt442
Jul 17, 2011 04:43 PM
