hello again !
Old Oct 17, 2007 | 05:47 PM
Good_Music_n_Cars's Avatar
hello again !
i have a basically stock 350 rocket. 4brl, edlebrock performer intake man., .. my question is, what would be the right cam for the engine. i don't want to over cam it. i would love the performance and the good sound that a cam provides. i was thinking of this COMP one, am i right??? what series should i go with also??? thank you much -Lee
http://www.jegs.com/webapp/wcs/store...10002_64424_-1
Old Oct 18, 2007 | 05:06 AM
Oldsguy's Avatar
Past Administrator
You won't notice very much idle "rumpity rump" with that one. But the more choppy the idle gets the less vacuum the engine will hold at idle. If you have power assist brakes, that is important. You could go with a cam with even a little more lift than that. There are so many choices out there and so many cam grinds that are so close to each other in specs. I would recommend that you look at Ultradyne cams too. They have a good reputation.
Old Oct 18, 2007 | 09:13 AM
$tryker's Avatar
Dan's got it right. If want to wake up the potential of the Edelbrock and 4bbl set-up, you can use something as large as this: http://store.summitracing.com/partde...K&autoview=sku
When the lobe centerline is in the 112 and up range, you should still be able to utilize the power brakes
Sounds like you want to keep the vehicle somewhat stock- convertor, etc. If so, stay under .500 lift and you'll be good to go.
Old Oct 18, 2007 | 11:22 AM
Jokers69's Avatar
Senior Moment
what year is the motor, what # are the heads?
Old Oct 18, 2007 | 12:27 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Important info.
also what rear end/gear.
If you are running a 74 smogger with #8s and a 2.41 gear you should probablyuse a different cam than say a 68 with #5's and a 3.73
Old Oct 19, 2007 | 02:23 PM
Jokers69's Avatar
Senior Moment
This is what I'm running in my 350 w#5 heads, ebrock performer, holly 600, turbo 350 with 3:73 rear end, I like it.
http://www.compcams.com/Technical/Se...umber=42-222-4
try that.
Old Oct 19, 2007 | 08:43 PM
thank you gents
thanks all of you for your reply! JOKER69, the link you sent was bad. can you send it again. thanks alot again everybody!!! -Lee
oldsfever
May 25, 2013 11:45 AM
GINA1
May 18, 2013 07:08 PM
Paul Deckon
Mar 17, 2012 08:02 AM
Nor Cal Andy
Oct 17, 2010 05:27 AM
jimjr
Apr 25, 2009 05:46 PM
