bolt size?
Old Jan 20, 2009 | 06:36 PM
72CUTTY's Avatar
bolt size?
hey guys i need help with some bolt sizes..
1. what size are the header bolts..( header to engine bolts)
2. what size are the lower header bolts ( header to exhaust bolts)
3. what size is the bolt on the driver side motor mount?
Old Jan 20, 2009 | 07:26 PM
hamm36's Avatar
1. 3/8 (corrected) standard thread 1 1/4" long should work (I had factory w/z longer)
2. ??? 3/8" use brass nuts. If holes both sides, I would use largest bolt that will fit tight.
3. 5/8 standard thread - 1" long should work
this is from memory from 6 mths ago. please correct me if I am wrong.
sorry this would be for a 455, not sure about 350 my guess the same.
Old Jan 20, 2009 | 08:00 PM
gearheads78's Avatar
car guy
Originally Posted by hamm36
1. 7/16 standard thread 1 1/4" long should work (I had factory w/z longer)
Head to exhaust flange bolts are 3/8 coarse not 7/16 unless BBO heads are different than SBO but I don't think that are.
On header pipes to collector all I have seen is 3/8 hole. I always use a bolt thats a little long and double nut it. Holds great but comes apart when needed much faster than a lock nut
Wildcard
Dec 9, 2012 10:35 AM
flatoz
Aug 9, 2009 06:49 PM
flatoz
Drivetrain/Differentials
Aug 9, 2009 06:48 PM
monzaz
Jul 6, 2009 07:51 PM
Wasted
Dec 31, 2008 07:04 PM
