Difference between "multi" & ""quote"?
Quote is for quoting 1 post, Multi-quote is used for quoting multiple posts. To use it, you would click on the Multi quote button on the initial posts you want to quote, however the last post in the group you need to click on Quote. For example with 4 posts you would like to quote, the first 3 click on multi for each one, but click on quote for the 4th.
[QUOTE=oldcutlass;1567981]Quote is for quoting 1 post, Multi-quote is used for quoting multiple posts. To use it, you would click on the Multi quote button on the initial posts you want to quote, however the last post in the group you need to click on Quote. For example with 4 posts you would like to quote, the first 3 click on multi for each one, but click on quote for the 4th.[/QUOTE
Oh, wow!
Just like this.
For sure.
Agreed, had to try it out for myself, works well.
Oh, wow!
Just like this.
For sure.
I kinda get this but how do people just take certain parts of a quote ? i see it all the time but not sure how it works for instance if i just want to quote a sentence out of someones long post?
Nail the quote button, it will pop up in a reply, and delete all you don't want.
