74, 75 delta 88 conv. parts.
Old Jan 26, 2016 | 07:17 AM
bigdooly's Avatar
Parting out 75' Delta 88 conv.
2 th375
I have some parts left, 1974 - 76 delta 88, 2 good th375's, some STEERING columns, dash & interrior, instrument clusterss, a.c. compressor & brackets, drive shafts, 74 tail lights, odds & ends, etc.
Old Mar 31, 2016 | 05:33 PM
ioldsnut's Avatar
Any idea if the power antenna works? If so, what ya want for it?
Thanks, Reggie
Old Apr 1, 2016 | 01:09 AM
bigdooly's Avatar
Thanks, Reggie
Hi Reggie, not sure if it works or not. will try to check it out after work today, weather permitting. I also have boxes of parts that came with another car I bought recently, I will look through & get back to you.
Old Apr 1, 2016 | 07:57 PM
bigdooly's Avatar
Thanks, Reggie
Sorry Reggie, I have no funtioning power antennas
Old Apr 2, 2016 | 09:30 AM
oldsdodger's Avatar
Looking for passenger side sun visor with lite mirror for 75 olds delta 88 convertible. Hinge on mine breaking away. Ours is red but should be able to dye/paint a clean one.??? Thans, Don
Old Apr 2, 2016 | 10:11 AM
bigdooly's Avatar
Visor
Hi Don, don't have any visors with lighted mirror, if I'm understanding correctly. I have a couple of visors you could possibly strip the hinge from. I have a black one with a small tear, from a 74 coupe, mirror missing. I 'll see photo if you like.
Jim
Old Apr 2, 2016 | 02:28 PM
Octania's Avatar
pm sent
Old Apr 2, 2016 | 07:41 PM
ioldsnut's Avatar
Oh well.. Thanks for looking. .
Old Apr 23, 2016 | 09:27 AM
Kilmster's Avatar
Any idea if those door panels would fit a '71?
Old Apr 23, 2016 | 12:32 PM
bigdooly's Avatar
Old Apr 23, 2016 | 12:54 PM
bigdooly's Avatar
Yes, but I need them , They are the reason I bought the car. I sent p/m, i have some other panels.
Old Apr 25, 2016 | 02:45 AM
calibones's Avatar
I'd be interested in any of these if you are willing to part with them
-Pinch Weld Molding
-Steering wheel (not the whole column)
-Right front inner wheel well
Old Apr 25, 2016 | 05:53 AM
bigdooly's Avatar
-Pinch Weld Molding
These are not parts I need, I would sell them, let me check the condition of them. Need specifics on pinch weld moulding.
I 'll send you a pm
Old Apr 26, 2016 | 03:12 PM
calibones's Avatar
Great, I marked up some of your photos of what I am interested in.
Old Apr 27, 2016 | 07:05 PM
Kilmster's Avatar
Bigdooly - I never saw a PM. If you have some door panels, I might be interested. mine were 'redone' and they're not very good.
thanks,
Mike
Old Apr 27, 2016 | 09:01 PM
bigdooly's Avatar
thanks,
Mike
Sorry Mike. Do you need all the panels? Upper , lower, front , rear? I have front left & right upper & lower, not perfect. I will send photos when I get a chance.
I don't have rear panels to spare, as I need them for my car. Sorry about pm must have gotten side tracked.
Old Apr 28, 2016 | 02:57 PM
bigdooly's Avatar
Old Apr 30, 2016 | 11:14 PM
calibones's Avatar
Just what I'm looking for. Looks like its in pretty good condition. I'd also be interested in that piece of fender trim on the front left side. I really need it for the rear drivers side fender but hopefully they are identical.
Old May 1, 2016 | 12:02 AM
rad's Avatar
rad
how about an am/fm 8 track radio for my 76 delta 88?
Old May 1, 2016 | 05:05 AM
bigdooly's Avatar
Actually, there is an 8track in the car, I have to test it, it May be an am only 8 track, not sure, I will get back to you.
Old May 1, 2016 | 05:09 AM
bigdooly's Avatar
wheel well Moldings different front to rear, I have a bunch of them for the front fenders, and a few rears, I will go throu them today, and get back to you, Right Rear is what you need specifically, correct?
Old May 1, 2016 | 05:10 AM
bigdooly's Avatar
Left rear sorry
Old May 1, 2016 | 01:52 PM
bigdooly's Avatar
Radio is AM only- 8 Track, No FM, sorry. First one I've ever seen.
It is a GM radio. If still interested, let me know, and I'll test it out, there are no speakers in the car.
Thanks, Jim
Old May 2, 2016 | 07:51 AM
bigdooly's Avatar
Regarding wheel well trim, 1 have 9 pieces only 1 of which is a left rear. I need to save this for my car. The FRONT AND REAR ARE NOT THE SAME, I matched all piece to parts car just to make sure.
Left front compated to left rear
I have 3 left front
1 right front
1 right rear, that I can part with.
Sorry. I am still looking for coolant reservoir bracket.
Thanks for you patience.
Old May 2, 2016 | 08:13 AM
bigdooly's Avatar
I have 3 left front
1 right front
Sorry. I do not have an extra bracket for coolant reservoir. I did find cap.
Old May 3, 2016 | 12:26 PM
bigdooly's Avatar
thanks,
Mike
The mirror you asked about, not sure if photos went through on p/m I sent.
Old May 5, 2016 | 07:54 AM
bigdooly's Avatar
-Pinch Weld Molding
It's in good shape, a couple of the bolt holes where it attaches to wheel arch in fender broke , but otherwise solid, no cracks, one of the better ones I've come across.
Old May 5, 2016 | 11:31 AM
rad's Avatar
rad
Bigddoley I think I might have found one here local, a guy I bought some parts from had a bunch of radios on a shelf and I think hes got one for me Thanks for the reply
Rad
Old May 5, 2016 | 04:05 PM
bigdooly's Avatar
Rad
Ok, good luck hope you get what you need
Old May 8, 2016 | 09:22 AM
bigdooly's Avatar
-Pinch Weld Molding
This is from a 74 ' 88
1975 wheel, cracked nfg.
Old Jun 3, 2016 | 05:54 PM
1974IndyDelta12345's Avatar
Auto Enthusiast
That coolant tank looks pretty good, still have it and what do you want? Also, the convert top switch that goes in the dash....up/dn switch?
Old Jun 3, 2016 | 08:58 PM
bigdooly's Avatar
Old Jun 3, 2016 | 09:02 PM
bigdooly's Avatar
Hello , conv top switch I used for one of my cars
Coolant tank $30. + SHIPPING. I will send
P/m
Old Jun 9, 2016 | 03:07 PM
triggerman's Avatar
what kind of money would you have to have for a LH front wheel opening and the LH rocker molding and I would appreciate pretty nice stuff as I had a tire explode and mine were almost mint. T
hanks
Old Jun 9, 2016 | 03:18 PM
bigdooly's Avatar
hanks
Sorry to hear of your mis fortune. I have a few L/H front moldings, I've sold a few at $30 + shipping. I jut sold a pair of rocker moldings, $ 45 ea. The one on black conv is still available. I will Pm my ph # if you prefer to call. Thanks , Jim
Old Jun 9, 2016 | 03:21 PM
triggerman's Avatar
that would be great
Old Jun 17, 2016 | 01:02 PM
bigdooly's Avatar
Bump
75' 88 conv. parts. Also 74 parts
good running 350 / 2 th375 trannys, steering columns, instrument clusters, accessory brackets, seatbelts, lots of stuff from numerous 88's Ive parted. The 74 convertible has been scraped, but still have some parts. The 75 has a bent chassis , and the tail lights have been sold.
Bump
Old Jul 7, 2016 | 12:13 PM
bigdooly's Avatar
Bump
Bump
Old Nov 7, 2016 | 03:14 PM
Aneecia1994's Avatar
Buying parts
I'm interested in purchasing 2 front doors all intact and 2 back tail lights, do you have a contact number? My number is 346-226-9394 Anthony
Old Feb 11, 2017 | 08:23 PM
75vert's Avatar
75 delta 88 parts
How's it going ?
I'm new to the site , I'm in search of a passenger side rear quarter panel for a convertible ? Thanks
