Wanted: 1964 330 block
Old Apr 26, 2014 | 09:58 PM
  #41
Keener's Avatar
Originally Posted by 2blu442
Still looking. I need to keep one for my project, and so far I've come across one on a 1964 that looks like the picture in the other thread. Then one on a 1966 that looks slightly different. The rubber where the metal pipe goes is smaller and offset just off center. It also doesn't have the nipple on the side as the 1964. So they may have had differences between the years.
John
The one I need does not have the nipple on the side. The one with the nipple is a vacuum connection for the PCV setup. The other is just a breather. Please send a pic to my email of the one from the 66. thanks
Old Apr 26, 2014 | 10:01 PM
  #42
Keener's Avatar
Originally Posted by Run to Rund
I have a pair of #1 heads that take rocker shafts.
Thanks, but I need the block. I would take a short or long block, but do not need heads without the block.
Old Apr 27, 2014 | 12:12 AM
  #43
nsnarsk65cutlass's Avatar
John
Not trying to hyjack the tread ,yes 64 breather is the same as 65 except for a small vacumn line attachment on the side.Nick
Old May 2, 2014 | 10:51 AM
  #44
CQR's Avatar
CQR
Not mine, Just saw the posting for it.
http://denver.craigslist.org/pts/4432999587.html
Old May 4, 2014 | 08:48 AM
  #45
Keener's Avatar
Thanks, COR. I've replied to the ad, waiting to hear back. Highly doubt it's an original 64 442 engine. Seller is probably confused because it has the high compression heads and the block reads 381917. On the outside, there is no way to tell it's a 442 engine. unless, you have the POP and the cars build or broadcast sheet.
Old May 7, 2014 | 07:25 PM
  #46
Keener's Avatar
ttt, need a 330 block, julian date code 89-105 (this corresponds to 4A, 4B and 4C on the data plate), correct block will have a #1 or 2 above the 89 to 105 number by the distributor. Also, number above timing chain cover should be 381917 followed or preceded by a #1.
Old May 7, 2014 | 07:36 PM
  #47
bassinguy's Avatar
sent a pm
Old May 16, 2014 | 09:50 PM
  #48
Keener's Avatar
ttt, see post above regarding details of the engine I'm looking for, thanks.
Old Jun 10, 2014 | 06:31 AM
  #49
lemoldsnut's Avatar
If you are still looking I can do a long block.
email direct at lemoldsnut@aol.com
calls between 8 am and 8 pm west coast time 541-815-4363
Larry Moyer
Redmond, Oregon
Old Jun 11, 2014 | 03:44 PM
  #50
lemoldsnut's Avatar
Checked and julian date is 292 sorry
Old Jun 11, 2014 | 07:34 PM
  #51
Keener's Avatar
Thanks for taking the time to look, Larry. To everyone else, please look at the 330's you have stored away. I would like to get this engine project under way. Remember, Julian code of 89-105. Thanks.
Old Jul 26, 2014 | 10:16 AM
  #52
2blu442's Avatar
Keener, I've got a friend here in Medford with one that's either a 73 or 78. I know that's outside the range you posted, but if you decide it would be close enough to work let me know and I'll help you get in touch with him.
John
Old Jul 28, 2014 | 12:17 AM
  #53
64Rocket's Avatar
I have a '64 block and crank.
also a set of '64 #1 heads with shafts
Gene
import extermination
Nov 27, 2011 08:25 PM
acre03
Mar 29, 2009 03:11 PM
DennisG.
Oct 29, 2008 10:38 AM
Run to Rund
Aug 4, 2008 02:08 PM
