69 Cutlass Clock
69 Cutlass Clock
Looking for a working, or new, clock for the tach/clock gauge. Tach works fine, but the clock is dead. Either parts or a place to go appreciated.
If you replaced the hands, would a full size clock with the proper face work? (Is the mechanism the same size?)
Steve P
El Paso
Steve P
El Paso
Steve,
A lot of times these old movements just need to be cleaned and lubed. They can come back to life.
I don't believe you can use the movement from a clock only option to fit the U21 rallye tac/clock
Thanks to all who looked! I decided to order a quartz movement for the original tach/clock unit and will replace the clock. Got the tach working again, so it will all go back in. I am going to keep the clock and one of these days get it serviced and running (if possible).
