Ac Problems
Old May 9, 2024 | 11:24 PM
Mr Top Notch's Avatar
1971 Cutlass 4 Door
Question South L:ouisiana 1971 cutlass Supreme
hi my cutlass A/C is blowing at bottom and not the top anyone has delt with this issue before that can help??
Old May 10, 2024 | 12:08 AM
1971 Cutlass 4 Door
Question Ac Problems
i have a 1971 Cutlass supreme my A/C wont blow on top but its blowing at the bottom can anyone guide me in right direction??
Old May 10, 2024 | 01:20 AM
The doors in the HVAC box that direct the air are vacuum operated. They are designed such that if vacuum is lost, the airflow defaults to the lower (heater) ducts and the defroster duct. The cause of your problem could be as simple as a vacuum hose that got knocked off (like the one that goes to the intake manifold that provides the vacuum source) or a bad vacuum actuator that operates the doors. The only way to figure this out is to crack open the Chassis Service Manual, turn to the page in the air conditioning section that shows the hose routing, and trace the hoses until you find where the problem is.
Old May 10, 2024 | 01:23 AM
Also, it is neither necessary nor in your best interest to post the same question in multiple threads. Keeping all responses in one place will get you a better answer more quickly.
Old May 10, 2024 | 03:55 PM
1971 Cutlass 4 Door
thanks, will check
Old May 10, 2024 | 04:22 PM
As Joe noted above, there is a vacuum hose that connects from the intake manifold behind the carburetor the the vacuum reservoir on the firewall, then a hose that goes from the reservoir through the firewall to the AC controls.
Here's a picture showing where the reservoir is located:
https://classicoldsmobile.com/forums...utlass-138738/
Old May 18, 2024 | 05:59 AM
1971 Cutlass 4 Door
thank you will look into this when i get home
keyboard
Sep 6, 2023 02:30 PM
vCode442
Dec 10, 2019 10:15 AM
Gabino
Sep 5, 2017 03:22 PM
Grace Stinespring-Welch
Jul 14, 2013 07:29 PM
dilges1
Nov 3, 2010 05:45 AM
