1968 Cutlass tilt and telescopic column
Old Apr 30, 2011 | 12:06 PM
1968Cutlassfallbrook's Avatar
Hello,
I was wondering did cutlass have a tilt and telescopic column or was it tilt only? What's a tilt and telescopic column worth if able to find one? Also What is a tilt worth able to find one. The ones I'm talking about are with the shifter on the column for automatic. Thanks
John
Old Apr 30, 2011 | 12:12 PM
rocketraider's Avatar
Oldsdruid
Tilt only for Cutlass. Tilt-telescopic was for big cars and Toronados.
Column shift automatic is going to be the easiest to find. It can come from any A-body GM vehicle but 68 is a one-year only column meaning $$$ because the Chevelle and GTO guys all want it too.
Old Apr 30, 2011 | 12:15 PM
If someone wanted to install a tilt-telescopic in a cutlass is it possible or are they to long? I had found one for a Toronado. What do you think I'd pay for a tilt only for a cutlass if I were able to find one?
Old Apr 30, 2011 | 02:24 PM
starfire's Avatar
Well you can get an aftermarket tilt column for the '68 from Ididit for about $375 so I would expect to spend at least that much, probably much more.
starfire
Dec 9, 2021 08:21 PM
ELECMAN
Jan 22, 2012 01:49 PM
ros6872
Feb 24, 2010 05:50 PM
ewingr
Nov 14, 2007 09:18 PM
