Over heating issue
Over heating issue
Finished brake job and took my 72 olds cutlass 350 for a quick spin to set and test the Brakes.. traveled about a mile and returned to barn and radiator was over heating and flowing out the reserve bottle...boiling out most of the antifreeze.
It has a new radiator, radiator cap and a shroud....
Any ideas?
Any ideas?
Is the light coming on? Are you filling the radiator to the top of to the fill level shown on the rear of the radiator, passenger side. Usually about 1 1/2 inches of head space. Or, Did you buy an overflow tank and cap that allows coolant to move in and out of the radiator as the coolant expands and contracts?
Over heating
Next step is change out thermostat, maybe light sensor too.
During my first test run a couple months ago I notice steam coming out seam in side of old radiator... Took it to be repaired and they said it was beyond repair so I bought new one and replaced... finally finished brake job and this is my result.
What brand - pn radiator did you buy? Yes water expands as it heats up, it should only by filled about 1/2 - 1 inch over the trans cooler looking down into the radiator. You are in the never ending cycle of overfilling and then having the radiator puke the excess out the overflow.
The temp sensor is at the front of the engine, with the key on you can test the wiring by removing the wire and touching it to ground, the light will come on. I prefer a mechanical temp gauge to monitor at all times. In addition I like a mechanical oil pressure gauge, and a volt meter.
Aluminum with plastic tank? How many core is it?
https://www.autozone.com/cooling-hea...eVehicle=false
