Window adjustment
Old Jul 13, 2018 | 05:18 AM
craig442's Avatar
Window adjustment
65 442 - Hilday Coupe - How do you move the door window rearward? It lines up fine, jest needs to move towards the rear window about 1/16 inch. Any help would be appreciated.
Old Jul 14, 2018 | 04:21 PM
Rocketowner's Avatar
I may be asking a foolish question ,but on a holiday coupe could it be that you need to adjust the rear window to stop further forward. Seems to me that the front window should run snugly in the felt at the front of the door glass , and any adjustment made to move it backward would bring it away from the front channel. Just my thoughts, I may be wrong ,if so ,I am sure someone will say so. Good luck ,Larry
Old Jul 15, 2018 | 07:33 AM
^^^THIS!
The door window MUST be fully forward in the channel of the vent window frame. If you move it backward, you'll get a gap at the forward end. Adjust the REAR quarter window.
Also, start by reading the window adjustment info in the 1965 body service manual.
Old Jul 15, 2018 | 10:11 AM
craig442's Avatar
Thanks Joe - I'll try to adjust the rear window to bring that forward a bit. I did read the SM, it always speaks to cocked windows, or windows that need to be moved in and out, I don't see it mention forward and backward.
tony442w31
Dec 6, 2015 10:18 AM
armycav0
Nov 1, 2014 09:10 PM
willj
Dec 23, 2012 01:42 PM
Four Four Tony
Apr 12, 2010 08:26 AM
ctrain22
May 30, 2009 08:45 PM
