Frames
Old May 15, 2018 | 05:19 PM
Collegecutlass's Avatar
Frames
Hey everyone,
just to clarify, a '67 Cutlass frame cant be used to replace a '65 Cutlass frame, right? I believe 64-65 are interchangeable, but that's it. Trying to get a replacement frame for my '65. Thanks in advance.
Old May 15, 2018 | 05:24 PM
Run to Rund's Avatar
66-7 front frame horns are spread farther apart to accommodate the cross flow radiator that was introduced for 1966. Additionally, for 1967 the rear spring upper perches in the frame were formed for pigtail spring ends. Up through 1966, the upper end of the rear spring was tangential.
Old May 16, 2018 | 07:01 AM
lemoldsnut's Avatar
I have a couple of 65 frames if you need one.
Larry
Joel n
Nov 19, 2007 01:48 PM
troys2222
Feb 20, 2007 06:02 PM
MAGIC253
Jan 2, 2007 04:32 AM
volivar
Oct 15, 2006 10:17 PM
<ohio2atl>
Jan 28, 2005 11:38 AM
