There are only about a hundred possible causes of this.
Obviously without MUCH more detailed info on the car and the conditions under which the problem occurs, we cannot provide useful information.
I ***-U-ME this is a gasoline 307 with CCC? Is the car totally stock or has some of the emissions equipment been tampered with? Does the problem happen on a cold start? After warm up? After hot start? Did it recently start? What work has been done to the car? Etc, etc. The mind reading still isn't working.
The definition of "flutter" is "to fly unsteadily or hover by flapping the wings quickly and lightly." I think he's telling us what he has to do with himself, not the car, to keep it running.
It just started recently. After I had to bypass the heater because it was leaking.
The word you're looking for is not "flutter," but "feather." Feather has lots of meanings besides being part of a bird, and one of them is to tap something, in this case a gas pedal, lightly and repeatedly, which is what we assume you have to do to keep your engine running.
