Door Question
Old Jun 11, 2010 | 08:33 AM
kanskidoo's Avatar
Door Question
Will a door from a '65 hardtop Cutlass interchange with a '65 convertible door? I'm assuming they will, but would like a second opinion. Thanks.
Old Jun 11, 2010 | 02:57 PM
You are correct, they will interchange. The only thing to be aware of is that the convertible doors have a bolt-on wedge plate at the back edge of the door. Just transfer it to the hardtop door. You'll probably need to drill holes for it.
Old Jun 11, 2010 | 08:26 PM
66400's Avatar
You will need to transfer the door glass as the hardtop and convert glass is different.
Henry
Old Jun 12, 2010 | 09:52 AM
Henry
Are you sure? It's the same in other years.
Old Jun 12, 2010 | 05:15 PM
66400's Avatar
Yes I am. 64 and 65 A body door glass varied between converts and hardtops. 66-72's GM A bodies shared the same door glass between converts and hardtops.
Henry
Old Jun 12, 2010 | 05:37 PM
Oldsmaniac's Avatar
I swapped 64 hadrtop doors onto a 64 Cutlass conv. if the glass was not the same I did not know the difference and everything looks and works fine.
Old Jun 13, 2010 | 12:37 PM
kanskidoo's Avatar
Both cars are '65 F85 Cutlasses. The guy who is interested in the door is going to replace his complete convert. door with my hardtop door. I noticed differences in the hardtop door's window mounting compared to my post car's window mounting....as well as the quarter window mounting....but I don't have a convert. to compare the hardtop to.
Old Jun 13, 2010 | 02:25 PM
Window mechanisms in post cars are completely different from those in HTs or convertibles.
jonn
Dec 2, 2014 12:06 PM
ddx77
Jun 24, 2010 10:49 PM
airlamb
Nov 29, 2009 11:46 PM
jmac69cutty's
Apr 13, 2009 07:42 AM
eke82
Ninety-Eight
Dec 14, 2006 05:40 PM
