Core support?
Old Aug 13, 2013 | 01:55 AM
Ronin775's Avatar
Core support?
Can I use a 1973 core support for a 1977? Both are Cutlass supremes. I believe that is the correct name,i attached a pictures of the part i need,also if the two won't fit where might i find one?
Old Aug 13, 2013 | 04:06 AM
DarrylJ's Avatar
I'm not sure if the 2 are interchangeable. The 76-77 nose is quite different from the 73-75. I would check some junkyards for that piece or someone on here might have one. Good luck!
Old Aug 13, 2013 | 04:32 AM
Ronin775's Avatar
Appreciate it.
Old Aug 13, 2013 | 09:47 PM
Ronin775's Avatar
So i can get a 73 core support from the junk yard,but i'm trying to be certain if it will work or not.
Old Aug 14, 2013 | 12:50 PM
Hurstolds1973's Avatar
My 73HO
The 73- 75 core support is interchangeable . The 76-77 are also. So the answer is no a 73 will not fit your 77..
Old Aug 14, 2013 | 12:51 PM
Ronin775's Avatar
jensenracing77
Jan 25, 2018 04:16 PM
rcktdoc
Jul 14, 2014 12:38 PM
esisson
Jan 14, 2007 04:38 PM
8valve
Dec 3, 2006 03:29 AM
