convert boot
Old Oct 7, 2011 | 12:30 PM
willr's Avatar
convert boot
have a 95 convert. having hard time getting it to fit and stay down. are there any specially shops who are good at fitting and matching colors for a boot?
Old Oct 7, 2011 | 01:30 PM
I might suggest you list what 95 car you have.
Old Oct 10, 2011 | 08:39 AM
willr's Avatar
you are right it might help!!
i have a 95 olds cutlass convert
Old Oct 10, 2011 | 09:54 AM
Olds Dad's Avatar
Collector of Stray 55's
boot on my '92 convertible fits horribly as well - I think they were all like that - almost seems like it was an afterthought....now, if I could just get my quarter windows to go down...
Old Oct 11, 2011 | 04:47 AM
oldsfever's Avatar
I have the same issue with a 94. I had another 94 that I bought an aftermarket boot and it fit better than the factory that I have this time. One side, normally the right, always pops up. I'm beginning to think it's because the top doesn't lay down like it did originally from thr wear. Maybe it's bent or warped a little.
Old Oct 11, 2011 | 11:51 AM
willr's Avatar
boot
willing to try just about anything at this point. can you supply source on this after market boot
thanks
Old Oct 14, 2011 | 04:51 AM
oldsfever's Avatar
Here's a link to the eBay store I bought mine from.
http://www.ebay.com/itm/1991-1995-OL...item519a08614f
Old Oct 14, 2011 | 02:28 PM
willr's Avatar
thanks for the info. went to ebay and viewed some pictures of the boot. These boots had 2 straps that hooked inside the trunk and attached to the boot. that is not the case with my boot. Did your boot come with thses straps?
willr
Old Oct 15, 2011 | 05:14 AM
oldsfever's Avatar
Yes, it did and it had the snaps inside the trunk. I don't on my current 94 and I don't know the difference. I don't have a problem with the rear of the boot coming up on this one, it's just the right side. I keep adjusting and trying to get the top to lay in the compartment lower but so far I have not had much success.
Old Oct 17, 2011 | 12:22 PM
willr's Avatar
boot
I know you have probably tried this--but the two rear drop points on the frame have adjustment bolts that will lower or raise the frame. Ihave to lower the top as far as the motor will take it and then put a wrench on the nut. I have lower mine as far as I can, but it still needs to drop lower. Probably the same problem you are having.
ps need to have new mufflers installed. would like to put a little sizzle the rear "look". chrome exhust, and high polished mufflers. Have you tried any of these online outfits?
willr
Old Oct 18, 2011 | 04:45 AM
oldsfever's Avatar
Yeah, I've tried that adjustment. I'm thinking the frame is bent or warped. No, I haven't tried any of those. I had a new muffler installed but it was at a local shop.
69442murph
Jan 28, 2015 07:34 AM
vistacruiser1971
Nov 9, 2013 01:19 PM
dingusboy
Care and Appearance
May 17, 2009 12:14 PM
TPP
Jan 12, 2008 07:36 PM
Mr.Smooth
Mar 13, 2007 12:29 AM
