Winter project
Old Jan 21, 2012 | 07:14 PM
Railguy's Avatar
Winter project
Going to have some work done to the heads so I can use shorter push rods and get the geometry right on the rockers also new roller rockers.Everything looks good inside the motor.Right know I'm weighting on the heads to get back from the machine shop.
railguy
Old Jan 21, 2012 | 07:20 PM
Railguy's Avatar
I forgot this.
Old Jan 29, 2012 | 01:42 PM
Railguy's Avatar
new roller rockers
railguy
Old Jan 29, 2012 | 02:59 PM
Did you just do a recent rebuild on your engine? It looks amazingly clean. BTW did you have to change your VCs when you go to roller rockers? Don't know if they are the same height as stock rocker arms.
Old Jan 29, 2012 | 04:53 PM
ziff396's Avatar
I have scorpions on my 455. I had to use 3/8" spacers to run stock height valve covers. It's not the rockers, but the studs and the adjusting nuts that are the problem.
Old Jan 29, 2012 | 05:20 PM
Rickman48's Avatar
Couple tips;
Copper exhaust gaskets make it a 'last time' situation!
Measure all 4 corners with a adjustable pushrod, if the block wasn't decked - could vary by .010 or more, order pushrods accordingly.
Old Jan 29, 2012 | 06:56 PM
Railguy's Avatar
The block was decked but that doesn't sound like a bad idea.I checked one valve and the push rod was at least 1/8inch long.
railguy
Old Apr 10, 2012 | 04:43 PM
Railguy's Avatar
Heads are back on waiting on the intake now.
railguy
rkk69olds
Jan 12, 2012 07:45 PM
Hark442
Oct 11, 2011 09:06 AM
442b
May 8, 2011 06:29 PM
stan 65 cutlass
Apr 24, 2011 09:15 AM
scott_442
Jun 11, 2009 03:31 AM
