Window Felts Help
Old Feb 10, 2025 | 07:50 PM
TheGrumpyGuy's Avatar
Doctorate in tire demo
Question Window Felts Help
Hey all, I have a 1972 cutlass that is a 2-door sport coupe - it has a post and wing window. I need to get new window felts, but have been having trouble finding the correct kit for what I need, any suggestions?
Old Feb 11, 2025 | 06:05 AM
Steele Rubber sells them, but for some reason their website isn't working this morning.
Old Feb 11, 2025 | 06:18 AM
Steele Rubber has an eBay Store, as well. I believe their products are also available at OPGI.
https://www.ebay.com/str/steelerubbe...145687.l149086
Old Feb 11, 2025 | 06:19 AM
No sooner posted (above) & their URL website is back up running.
https://www.steelerubber.com/
Old Feb 11, 2025 | 01:20 PM
chip-powell's Avatar
I bought mine at OPGI a few years ago. Cost a bit more than other places, but the fit was perfect with no cutting needed.
PUI - Window Felts, 70-72 Cutlass, S, 442, Coupe, 8 pieces, Original Style @ OPGI.com
Fusick is also selling them.
Window Channel Kits (Sweepers)-www.fusickautomotiveproducts.com
Old Feb 11, 2025 | 05:30 PM
Thank you all! They are on order!
Old Feb 13, 2025 | 08:54 PM
cfair's Avatar
One vote for Steele on the quality front. There are a bunch of companies doing reproduction rubber - Metro, Soffseal, Steele and others.
At least for the big cars I have known for 40 years or so, Steele makes the best quality reproductions.
See the posts under my username comparing Steele to Metro and my latest adventure with their stuff on big cars. A body (Cutlass/442) may be different.
I have a few posts on getting rubber right. To be sure big cars are different from Cutlass/442’s, but the principles of cleaning window frames and getting seals seated and glued cross over.
Wishing you luck in replacing your seals.
Chris
Old Feb 13, 2025 | 09:04 PM
Chris
Thank you Chris
Old Feb 15, 2025 | 08:10 AM
79cut's Avatar
I found a local guy that sells parts for these. I bet there are some in your area
1980olds442
Apr 18, 2023 12:48 PM
eric66
Nov 4, 2021 11:05 AM
55Oldsmobile$
Oct 3, 2021 01:28 PM
tcarroll
Sep 25, 2014 02:37 PM
68cutlassman
Mar 5, 2008 10:52 AM
