What model
Old Aug 2, 2022 | 05:15 PM
Randomk's Avatar
What model
Hi, what model is this ? It's a 1972
and how much roughly is it worth. Runs and drives.
Old Aug 2, 2022 | 05:54 PM
Can't tell without the VIN. You can't even tell what model year it is, since it has obviously been messed with. ASSUMING it's a 1972, it's either a Cutlass Hardtop or a Cutlass S hardtop. The VIN will be different. The chrome trim on the leading edge of the front fender is a 1970 trim piece. The ill-fitting hood is either 1971 or 72. The grills are 1972 442, but they are likely reproduction anyway. The back seat upholstery that you can see in the photos appears to be 1971-72 also. Get the VIN.
Old Aug 2, 2022 | 06:01 PM
Randomk's Avatar
It is a 1972 cutlass 2dr hardtop 455 2barrel. Runs and drives interior is really good. What do you think it's worth. I got the vin and decoded it. Not sure if it's worth what he is asking. Let me know a rough estimate.
Old Aug 2, 2022 | 06:08 PM
If you already knew that, why did you ask "what model"? And is it really a Cutlass or a Cutlass S? Is it an original 455 car or not (that will also be in the VIN). Is this your car? Without more info and photos, the best value estimate is somewhere between scrap value and a million bucks. Provide more info, more photos, the VIN, and the cowl tag and you might get a more precise answer. You haven't even told us what transmission, drum or disc brakes, what rear axle, etc. It looks like the car is half assembled, which doesn't bode well for value. And FYI, the "455 2bbl" wasn't even available in the 1972 model year, so it's clearly not original.
Old Aug 2, 2022 | 06:13 PM
Randomk's Avatar
Sorry. It's not mine. Thinking of buying it. This is the first 8 of the vin, 3G87U2MI. Has a 455 with a th400 trans. Not sure about brakes. Runs and drives good.
Old Aug 2, 2022 | 06:14 PM
Randomk's Avatar
Old Aug 2, 2022 | 06:21 PM
Randomk's Avatar
Old Aug 2, 2022 | 06:31 PM
Randomk's Avatar
Just a rough estimate on what it is worth.
Old Aug 2, 2022 | 06:38 PM
Randomk's Avatar
He has all the orignal parts for the center console shifter and some other original pieces.
Old Aug 2, 2022 | 06:43 PM
3G87 is a Cutlass S Hardtop Coupe.
The "U" proves it is a factory 455 4bbl car with the L75 motor.
The engine pictures show a lot of modifications. I can't read the head casting to tell if this is the original engine or not. I can see a drum brake master cylinder.
If your real question is, "Is this a real 442", there is no way to tell without paperwork. The car has had most of the trim removed. And FYI, real 1972 442s did not get the 442 emblem on the glove box. This car would have come with a Cutlass emblem there. Now, back when the 72s were new, the first thing we did was run to the parts counter and buy a 1971 glovebox emblem. I did that with my own 72.
As for value, there are so many non-stock items that it is difficult to say. To me, these detract significantly from value. Someone else might not feel the same way. The fact that the car has apparently been torn apart and put back together scares me. Typically cars that exhibit half-fast workmanship like we see in these photos only get about half the fasteners reinstalled. Wiring is often totally hosed. Missing items like the trunk lock and outside mirrors just add to the negative vibes. Based solely on the information presented here,. I'd have a hard time going over $10K. 1972 U-code cars are pretty rare, but this one has so many issues that I can't see it even close to the value of a nice one. My other big concern is the condition of the sheet metal. Without knowing what's under that repaint, it's hard to make an accurate assessment.
Old Aug 2, 2022 | 06:44 PM
OLDSter Ralph's Avatar
Whats he asking ? What state is the car in ?
Old Aug 2, 2022 | 06:45 PM
Randomk's Avatar
I could buy it for 9k. Cali
Old Aug 2, 2022 | 06:46 PM
Randomk's Avatar
He says he has the broadcast sheet to prove its a u code
Old Aug 2, 2022 | 06:48 PM
The U is in the VIN. You don't need the broadcast sheet to prove it, we already know it is. Now, if the broadcast sheet shows that the car has RPO W29, that will prove it really is a 442.
Old Aug 2, 2022 | 06:50 PM
I could buy it for 9k. In colorado
Assuming it isn't a bondo-filled fright pig, that's probably not an unreasonable asking price. I'd negotiate down from that. $8k or so for a running driving car that isn't rusted out would be a decent deal.
Old Aug 2, 2022 | 06:52 PM
Randomk's Avatar
Okay what would you think it's worth if it is a real one. Currently asking for a pic of it.
Old Aug 2, 2022 | 06:53 PM
Randomk's Avatar
Old Aug 2, 2022 | 06:58 PM
Randomk's Avatar
He said, "It says w29 on the sheet under A52(Interior split bench) and all #s matches the u code on the vin ,body and production date"
Old Aug 2, 2022 | 07:21 PM
Randomk's Avatar
Should I go buy it tomorrow. Lol
Old Aug 3, 2022 | 04:58 AM
fleming442's Avatar
Did you get it?
Old Aug 3, 2022 | 05:19 AM
Randomk's Avatar
Well what do you think it's worth?
Old Aug 3, 2022 | 05:36 AM
fleming442's Avatar
It's worth at least the $8-9k you mentioned. Did you just stumble on to an undiscovered diamond mine that you can flip for 10s of thousands of dollars? No. It appears to be a nice car, though.
Old Aug 3, 2022 | 05:43 AM
A decently restored and documented 1972 U-code 442 will easily bring $25-30K, depending on the quality of the work. Unfortunately you're going to spend at least $10-15K more to get that car into such a condition. A lot depends on how the modifications were done, how much is hack work, what parts are missing and need to be replaced (yeah, I realize the seller CLAIMS to have the original parts...), and what shape the underlying sheet metal is in. It also depends on whether you are doing the work yourself of paying someone (in which case double my 10-15K estimate).
Old Aug 3, 2022 | 08:34 AM
GN1220's Avatar
Is it just me or is there not a window crank or window switch on this door? Also, if he has all of the "original" console and shifter why does it have a bench and column shift?
Old Aug 3, 2022 | 08:45 AM
GN1220's Avatar
Not to mention, I would be very skeptical regarding the quality of work by someone that doesn't even bother to jamb the car in on a color change repaint. But that's just me.
Old Aug 3, 2022 | 08:47 AM
Randomk's Avatar
Think I'm going to pass on it.
Old Aug 3, 2022 | 09:28 AM
fleming442's Avatar
Flippy McFlipperson
Old Aug 3, 2022 | 12:39 PM
vCode442's Avatar
Vincit qui se vincit
Walk up to his house with 7500 cash. Drive it home. A running 72 U code with W29 442 provenance must certainly be worth that.
Old Aug 3, 2022 | 02:09 PM
GN1220's Avatar
I have one for sale. Not a 442 but a real U code. See the for sale section if interested.
Old Aug 3, 2022 | 03:00 PM
Bryan Burch's Avatar
Just here to acknowledge, this is the first time I've heard of "half-fast workmanship". Thanks for the laugh! hah!
Old Aug 5, 2022 | 03:02 AM
  #31
OLE442's Avatar
Yeah, like a boss once said of one of my co-workers back in the day:
He's not slow and he's not fast, he's kind half-fast! LOL! I always thought that was funny! LOL
I think the approaching with $7500.00 cash might be good! You never really know for sure if it's a good deal or not until you own it unfortunately. Cash talks and even a bit less might work. I got a really good price on a 1969 BOSS 302 many years ago because the clutch went out while we were out in the country on a test drive. While we were waiting for the tow truck, I asked the owner just how bad he wanted to get rid of the car....and I bought it!
Mar 31, 2022 07:58 PM
paulnehus
Feb 9, 2020 01:08 PM
Kaline
Jan 7, 2018 08:11 AM
jpc647
Jul 15, 2016 09:18 AM
batmx3man
Dec 13, 2006 09:47 AM
