What is this ?
Old Jun 26, 2010 | 11:21 PM
toro455's Avatar
From: Issaquah, Washington ( 15 miles east of Seattle )
What is this ?
I was taking out my radiator and core support tonight to replace the rusted core support bushings. In the process I found some king of weird modification someone previous to me did to this car. On the left side of the core support someone cut and then peeled down a pice of the metal and made some kind of bracket with a tube.
I can't figure out what it is because it doesn't do anything. At one point it looks like someone installed a hood release maybe or routed ca cable through the tube for something. Maybe someone can give their thought on this strange modification by looking at the photo's. If I'm not making sense then just ignore me. Thanks
Old Jun 26, 2010 | 11:23 PM
svnt442's Avatar
I wonder if it could have something to do with the optional hood lock?
Old Jun 26, 2010 | 11:37 PM
toro455's Avatar
I didn't take a photo of this but there is also a metal loop bolted through the inside center of the radiator core support for no apparent reason. It may have something to do with this other modification.
So are you saying that this bracket might have been for a interior hood lock option ? That's not what the factory option looks like is it. Or was it a dealer installed option and that's what they had to do to install it ? Or is this someones "McGyver" way of adding little options ? Does anyone have a photo or picture of the actual interior hood lock option and how the cable was routed ? Is it like the photo above ?
Thanks for the probable answer.
Old Jun 27, 2010 | 12:29 AM
svnt442's Avatar
I've never actually seen one installed in a car and I believe this is not stock for it. It just looks like that is a possibility as to what that might have been for.
Old Jun 27, 2010 | 08:06 AM
Lady72nRob71's Avatar
Looks like part of a southern-engineered hood lock.
The factory option would not have been installed that way. It would be all underneath the core support top plate next to the latch. It would not have looked rigged up either.
Old Jun 27, 2010 | 09:11 AM
jrsixx's Avatar
I remember the old dealer installed hod locks from back in the day. They were like a hood release cable, just a bit thicker and they pushed in instead of pulling out. When I worked at an Olds dealer in the 80s, we sent them out to be done, meaning the quality of the install/pieces used to install, weren't always top notch, even to the point of being "southern engineered".
Old Jun 27, 2010 | 11:15 AM
toro455's Avatar
Thanks everyone ! I think this modification has been there for a long time hidden from view under the radiator shroud material on the sides of the radiator. If I get a chance later I will post the metal "O" loop mounted to the inside center piece of the radiator cord support. This must be part of the cable system installed with the part above.
Old Jun 27, 2010 | 12:47 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Might of have been a J.C. Whitney special.
Old Jun 27, 2010 | 08:01 PM
mike's88's Avatar
Did the car at 1 time have an alarm system installed? It might be a left over, after previous owner just removed the underdash key and associated wiring. Just a thought.
Old Jun 27, 2010 | 09:25 PM
toro455's Avatar
What is this - part two.
Part two: Here are two more photos to make anyone's guess even more difficult. Take a look, see what you think....
mike's88 - To answer your question, I'm not sure what this car had other than an ignition cut-off switch routed into the glove box. I don't see any signs of an alarm being installed ever but then again I didn't know this cable thing was there until this week. I've only owned the car for two years. You make a good point, so I will pay attention and keep an eye out for extra wiring for an alarm.
Old Jun 28, 2010 | 05:38 AM
Either a "recovery hook" or still part of the southern-rigged hood latch.
Hmmm.... Previous bike brake cable goes to inside car with chinesium locking pliers on end as a handle, string is tied to other end of cable, string goes through hook and up to hood latch. Six inches of cable pull ~might~ pop the hood one time out of six.
What did I win?
Okay, I'm not on acid, but I have seen totally rediculous rigs before, some worse than this.
Maybe it was on "thereIfixedit"...
