Visor mirror
Old Aug 27, 2016 | 04:37 PM
Gmcdually's Avatar
Visor mirror
Is there a way to change out these mirrors without damage to fabric , any help would be appreciated
File Type: jpeg
Old Aug 27, 2016 | 08:15 PM
rcorrigan5's Avatar
Randy C.
I just changed the one out on my '69. I just popped it out using gentle pressure under the mirror with a screwdriver at the two points where the back snaps into the receptacles in the visor. It came out intact and I was even able to use the old receptacles for my new mirror.
Randy C.
Old Aug 27, 2016 | 09:23 PM
Depends upon if it's a factory mirror with the metal backing plate and two mounting posts or if it's an add-on that is a piece of glass glued to the visor. I don't see an Olds emblem on it like the factory one if my 70 Supreme but I don't know if all years had that or not.
Old Aug 28, 2016 | 09:31 AM
rcorrigan5's Avatar
Randy C.
I know the '68 and '69 originals did not have the Olds rocket on them. I was lucky to find a NOS mirror to replace the old one on my '68 but had to go with a Fusick replacement (which had the Olds rocket on it) for the '69. Although I'm an "original" sort, I do like the rocket emblem on the mirror for the '69!
And yes, both originals from my '68 and '69 had metal backing plates, as does the NOS mirror that went on the '68. The Fusick mirror for the '69 appears to have a plastic backing plate.
Randy C.
Old Aug 28, 2016 | 10:17 AM
So I guess the OP needs to say what year visors he is working on.
Old Aug 28, 2016 | 11:09 AM
Gmcdually's Avatar
Working on a 72 cutlass ,both the mirrors I believe to be original with no logo on either. I have tried to pry up gently, but with no luck . Thanks for the info.
Old Aug 29, 2016 | 10:26 AM
The factory mirror should have a metal backing plate, the same size as the mirror, with two posts that insert into receptacles in the visor. You would need to pry between the plate and the visor, very close to the posts, using the lip of the receptacle as a pry point.
If the mirror is glued directly to the visor, then I have no idea how to remove it.
Old Aug 29, 2016 | 06:21 PM
I have a number of mirrors, frames, and the posts, but I don't think I have a backing plate. Are those available from Fusicks?
Old Aug 29, 2016 | 07:50 PM
rcorrigan5's Avatar
Randy C.
The repro mirror I got from Fusick (came with the Olds rocket symbol on it) has a plastic-looking back plate on it. I don't think you will find the metal backed mirrors anymore unless you can get one NOS. And I don't believe you can purchase just the backing plate - it comes with the mirror.
I have my old original mirror from my '69 and have been wondering if it can be re-silvered.
Randy C.
Old Aug 30, 2016 | 03:56 PM
Gmcdually's Avatar
Success, thanks guys . I use little more force and both the old and replacement came off . Both had metal backing plates , friend of mine owns glass shop and is going to see about refinishing the damaged one . Keep you posted
RandyS
Nov 9, 2014 10:51 AM
Ceilingman
Sep 7, 2013 07:56 PM
dnmfranco
Aug 2, 2013 08:14 PM
Hank
Jun 23, 2013 01:38 PM
jeffreyalman
Jan 26, 2013 08:17 AM
