Upgrade rear end
Old Jul 13, 2014 | 02:04 PM
Trebla781's Avatar
Upgrade rear end
Anyone have suggestions to a nice upgrade from stock rear end on a 1971 cutlass Oldsmobile convertible, or where I can buy it
Old Jul 13, 2014 | 04:32 PM
Why are you looking to upgrade? I have read from some of the rearend gurus that the Olds bolt-in axle 8.5" 10 bolt rear is very strong and is good for 12s or faster in the quarter mile.
You can swap the original 28 spline axle shafts for aftermarket 30 spline shafts for a strength increase, and I'm sure there are a few other mods that can take that rear faster than 11-12s.
Old Jul 13, 2014 | 04:36 PM
pogo69's Avatar
morgan
Your going to need to be more specific on the upgrading for people to give opionions...do you want better milage better highway cruising better street performance posi...and what engine trans and rear do you currently have to let people know what you have
Old Jul 13, 2014 | 04:46 PM
Trebla781's Avatar
Sorry should have been more specific, I'm really new to cars and don't know much other then what my mechanic tells me, he said if I'm going to do work to my engine to beef it up I'm going to need to change out my rear end., I currently have a 350 engine and trans that I have no idea what year the engine is the car is a 71 cutlass supreme
Old Jul 13, 2014 | 05:15 PM
pogo69's Avatar
morgan
A stock olds 1971,3.73 10 bolt is pretty popular for street strip stuff i'm wondering what you have in there now and what the mechanics intentions are...does he think the axles are bad? You may be jumping the gun a little untill you know what your doing with the engine and what kind of power range you want
Old Jul 13, 2014 | 05:21 PM
Trebla781's Avatar
I just want my car to have some power behind it nothing crazy,at a dead stop I can put pedal to metal and it just takes off with no peel out.... how would I tell what I have in there now?
Old Jul 13, 2014 | 05:33 PM
RandyS's Avatar
There is a 2 letter code stamped on the rear of the passenger side axle housing. You may need to take a wire brush to it to see them.
Old Jul 13, 2014 | 05:36 PM
Trebla781's Avatar
thanks!
Old Jul 13, 2014 | 05:38 PM
pogo69's Avatar
morgan
The quickest and easiest way is jack up one rear tire turn the tire one complete turn as you are watching the drive shaft turn so if the driveshaft turns 3 1/2 turns for one complete tire revolution you would have 3.55 gears....this should be your first step knowing what equiptment you have
Old Jul 13, 2014 | 05:41 PM
pogo69's Avatar
morgan
I would of said to check the axle code also but i'm fat so its easier to just jack one side up a little
Old Jul 13, 2014 | 05:46 PM
Not quite. You have to take into account the differential action if one wheel is on the ground.
Originally Posted by Octania
Basically you spin the drive shaft until you have gotten two full turns of the rear wheel[s]- this can be one turn of both wheels if you have posi, or two turns of one wheel if you have an open diff, or any combination in between. 1.5 & 0.5 or whatever.
Use the driveshaft's convenient 90 degree features to count turns to the nearest 1/4 plus or minus a little, then consult the chart of possible ratios to peg it. For example if you get just past 3 turns but not to 3&1/4 then it must be 3.08-1 ratio.
You can go for 10x as many turns if you need more accuracy- e.g. 32&1/4+ driveshaft turns to get 20 turns of one rear wheel if the ratio is 3.23 on an open diff....
Old Jul 13, 2014 | 05:47 PM
Worst case is you wold need new gears and a limited slip differential. The rearend will hold up to more than your engine can throw at it.
Old Jul 13, 2014 | 05:50 PM
pogo69's Avatar
morgan
If you do decide to count the driveshaft per tire revolution put the trans in netral and remember safety first it will take you 5 mins
Old Jul 13, 2014 | 05:54 PM
Trebla781's Avatar
Thanks for the help guys! Gonna try and see what's under there soon as it cools off a Lil
Old Jul 13, 2014 | 05:55 PM
pogo69's Avatar
morgan
And of course it gets more complcated because with just checking the ratio with one tire off the ground that wont tell you if you have limited slip diff. You need both tires off the ground to check that if both tires move in the same direction its an open rear if one tire moves forward and the other backward at the same time its limited slip or posi terminology
Old Jul 13, 2014 | 05:57 PM
Trebla781's Avatar
Posi is when both tires spin correct? My car don't have that
Old Jul 13, 2014 | 06:05 PM
pogo69's Avatar
morgan
Yes both will turn only wth posi one forward one backcward
Old Jul 13, 2014 | 06:10 PM
pogo69's Avatar
morgan
The posi had to be be specially ordered or part of a high performance package so its not a surprise your is open, i dont know what the standard open ratio would be for a 71 though
Old Jul 13, 2014 | 06:20 PM
My car came with a 2.56 rear. According to the build sheet, that was the "no cost" ratio.
Old Jul 13, 2014 | 06:23 PM
I think you have that backwards. The limited slip tries to lock the axle shafts together and keep both wheels moving together.
Also, the wheels will turn opposite directions on any differential if the driveshaft is held in place (as in the trans is in Park or in gear for a MT). Doesn't matter if it's an open diff or an LSD. That's what keeps your car from rolling away when you park it.
Old Jul 13, 2014 | 06:26 PM
Gary M's Avatar
Turn the wheel 10 times ,count the revs of the driveshaft and then divide by ten. More accurate results. West coast differentials sells a posi unit and gears for the 10 bolt differential. This site times out too soon for me to be more descriptive. good luck. I lost all the info I wrote first time. Good luck.
Old Jul 13, 2014 | 06:27 PM
Same thing happened to me just now - typed up a buch o stuff and lost it all.
But again, you need to account for the differential action when counting turns.
10 bolt posi and gears are available from everywhere.
Old Jul 13, 2014 | 06:31 PM
Gary M's Avatar
The open rear will spin in opposite directions. The poster already indicated both wheels don't spin. The posi unit is a good investment if you plan to upgrade gear ratio anyway because the mechanic is in there anyway so do everything needed while he is at it.
Old Jul 13, 2014 | 06:35 PM
Gary M's Avatar
Idea
I may just copy me post before submitting it and if timed out and have to sign in again just paste to the new window. More than one way to skin a cat. ONE IMPORTANT THING. buy the OEM gears because they don't whine. (that gets old quick). WCD said the OEM gears are not loud.
Old Jul 14, 2014 | 04:09 PM
BlackGold's Avatar
Instead of spending your money on a new rear end, spend it on a good tune-up. A '71 Cutlass with 350 (even a 2-bbl) and no posi should be able to spin its right rear tire all day long.
Old Jul 14, 2014 | 04:16 PM
Trebla781's Avatar
what would a tune up consist of? I supposedly got one, the guy changed wires on spark plugs and new spark plugs also new distributor
Old Jul 14, 2014 | 05:50 PM
A new distributor? What type? Maybe the initial timing, advance curve, etc. are not correct.
Old Jul 14, 2014 | 05:54 PM
Trebla781's Avatar
I'm not sure what kind but I know that we bought one for a 1971 olds 350 and it was to short, we ended up getting one that goes in a 1978 and it fit right in.... I'm thinking this car has been messed with big time
Old Jul 15, 2014 | 12:23 PM
pogo69's Avatar
morgan
I just noticed this and thanks for the correction... didnt mean to confuse the question, hope you got the ratio figured out so you can go from there
Old Jul 15, 2014 | 12:30 PM
Trebla781's Avatar
Does anyone have a pic of where to look to find the number stamped on it?
Old Jul 15, 2014 | 12:42 PM
  #31
pogo69's Avatar
morgan
this is on my 1969 your will be in the same area (maybe higher) you may need a mirror and wire brush
Old Jul 15, 2014 | 12:44 PM
  #32
pogo69's Avatar
morgan
the silver area right to right of the duk tape
Old Jul 15, 2014 | 02:20 PM
  #33
Gary M's Avatar
My differential numbers on my 72 were on the front of the axle housing to the passenger side.
Old Jul 15, 2014 | 02:33 PM
  #34
Um, the distributor for any '64-up Olds V-8 is interchangeable (Aurora excluded). This means that the "too short" distributor was likely NOT an Oldsmobile distributor at all.
So if you have one for a '78 engine then it is an HEI distributor, and therefore its advance curve is totally different than the '71 points distributor. The HEI will need the initial advance set to ~20º in order for the total to be in the 34º range. HEI also uses different spark plug wires and needs a full 12 Volt power source and not the resistor wire used with the points distributor.
Old Jul 15, 2014 | 03:32 PM
  #35
1970-W30's Avatar
As Kenneth said, your timing curve is wrong with the 78 distributor, you've gone backwards in regards to a performance increase. My advise is for you is to find a mechanic that can explain things to you and for you to ask more questions from your mechanic. Make sure you tell the mechanic what exactly what your goals are and have him explain to you what needs to be done and why to achieve those goals.
Old Jul 15, 2014 | 03:42 PM
  #36
Trebla781's Avatar
Definitely going to talk to my mechanic, just wanted to get some insight from some real olds guys!
350TurBRO
Sep 12, 2014 11:52 AM
monzaz
Mar 22, 2012 07:20 PM
Mark71
Suspension & Handling
Jan 25, 2012 04:32 AM
Stattiolds69
Drivetrain/Differentials
Mar 16, 2011 05:06 AM
Aceshigh
Brakes/Hydraulic Systems
Sep 5, 2009 06:34 AM
