trunk lid for 68 cutlass
Old Apr 13, 2010 | 04:02 PM
johntrossi's Avatar
I am currently retoring a 68 cutlass supreme convertible and need a trunk lid. Any ideas as to where I might find one. I have found some glass reproductions but would really like steel. Any help is appreciated.
Old Apr 13, 2010 | 04:32 PM
starfire's Avatar
John,
If it is a 68 it is an "S" convertible. They did not have a Supreme convertible in 68. A trunk lid off of a 4-door Cutlass will also work with the "S" convertible.
BTW, where did you find a fiberglass trunk lid for a 68 Cutlass convertible?
Old Apr 14, 2010 | 05:09 AM
johntrossi's Avatar
It is a "S" convertible, I miss spoke. I found the glass lid at showcars-bodyparts.com, they had both pin on and bolt on. I have not been able to find a steel one as of now, but will be looking. I was hoping a 67 or 69 lid would fit.
Thanks for your input, where in SE Michigan are you?
Old Apr 14, 2010 | 08:36 AM
If you are looking for a metal repro, they do not exist. Good used is your only option. As noted, all four door trunklids are the same as convertible trunklids for 1968.
Old Apr 14, 2010 | 05:28 PM
starfire's Avatar
John,
I'm in Farmington Hills. You might want to check out our local chapter of the Oldsmobile Club of America, the Motor City Rockets
www.motorcityrockets.com
Alan
Old Apr 15, 2010 | 02:27 AM
Yellowstatue's Avatar
I have seen a '69 lid on a '68 convert...had the corners filled in and you couldn't tell from outside...
shamusj
Apr 7, 2018 08:10 AM
2blu442
Oct 18, 2014 04:55 PM
Bitburger
Mar 17, 2012 04:04 AM
goodkarmech
Mar 31, 2008 07:07 AM
