Toronado oil pan question
Old Jan 11, 2022 | 04:48 PM
Andy's Avatar
Just thinking, probably a dumb question but…how did mechanics get that trapped quart of oil out of the pan when changing oil? Or did the they just leave one dirty quart to mix in with the fresh?
Old Jan 11, 2022 | 05:35 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Good question. I think it probably got left in the pan.
Old Jan 12, 2022 | 06:57 AM
This is a case of "don't ask the question you don't want to know the answer to.. "
Old Jan 12, 2022 | 07:24 AM
Ozzie's Avatar
I wonder if a second drain plug would have been possible?
Old Jan 12, 2022 | 08:22 AM
edzolz's Avatar
Just a poor design between the Toro suspension and interference to the oil pan. There is not really a full quart left but enough to contaminate the new oil.
Old Jan 12, 2022 | 08:33 AM
JohnnyBs68S's Avatar
Can't be much worse than the old oil (and filtered trash) trapped in the old filter if it wasn't changed on a given oil change cycle (filter changes were recommended every-other oil change back in the day).
Old Jan 12, 2022 | 08:36 AM
stan 65 cutlass's Avatar
i had a 89 lincoln i think it was, had 2 drain plugs same pan design, if you didnt drain both you overfill the oil pan a bunch. ask me how i found out
Old Jan 12, 2022 | 08:52 AM
Andy's Avatar
😊. Indeed sir
Old Jan 12, 2022 | 09:44 AM
RetroRanger's Avatar
72 Olds CS
Hi Andy
i dont know if your looking for a larger capacity stock looking oil pan, but i saw this the other day, i havent seen these before.
https://www.ebay.com/itm/18462735141...gAAOSw82hfrJH1
Old Jan 12, 2022 | 02:50 PM
Andy's Avatar
Hi Andy
Thank you, really just a curiousity thing for me..
Old Jan 12, 2022 | 09:18 PM
A second drain plug would have been a good idea, but the bean counters probably would have thrown a fit over the added dime it would have cost.
I wonder how much oil the front sump actually holds with the car at normal ride height? If the car was on a typical 4 post hoist, it’s going to sit pretty much level The guy at home in his garage with a floor jack will obviously raise the front of the car, allowing just a little more oil to natural drain.
Old Jan 13, 2022 | 02:44 AM
shiftbyear's Avatar
There was a service bulletin to raise the back end of the Toronado 45 degrees during oil changes to purge oil pan... just kidding.
Old Jan 13, 2022 | 06:42 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
They sure did, changed quite a few of them when I apprenticed at the Ford dealer. See Ford had some good ideas😁.
Bandit60
Feb 9, 2021 06:36 PM
1939Olds
Jun 8, 2016 02:39 PM
88hurstolds
May 23, 2015 08:40 AM
tdozz13
Mar 23, 2015 08:14 AM
jag1886
Aug 3, 2011 07:17 PM
