TH400 Problem ?
Old Jan 8, 2013 | 06:07 AM
Bitburger's Avatar
TH400 Problem ?
I have a 69 98 with a 455 and a TH400. With or without the motor running and the trans in park the car will roll very easily.
What if anything is this telling me about the condition of the transmission
or is the problem elsewhere ?
Any help would be appreciated
Old Jan 8, 2013 | 06:13 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Shifter linkage missing? Or busted rooster comb in the trans?
Old Jan 8, 2013 | 06:30 AM
Bitburger's Avatar
J,
Thanks for the response. I will be pulling the motor in the next few days so missing linkage should become obvious. Re the rooster comb issue is that a fairly easy fix or is it leading to an overhaul of the tranny. The old as long as "I have this thing apart" philosiphy. Odometer shows 95k on it and I believe that to be correct.
Old Jan 8, 2013 | 06:47 AM
This is very simple. Either the shift linkage is misadjusted and not going fully into PARK, or the parking pawl inside the trans is not engaging properly. Either problem is easily fixed without removing the trans (though you do need to drop the pan to access the parking pawl).
Old Jan 8, 2013 | 07:01 AM
Bitburger's Avatar
Joe,
Thanks for the response. If the shifter linkage is misadjusted would the car start as it should in park ( ie. without physically holding the lever up ).
Old Jan 8, 2013 | 09:08 AM
7olds1's Avatar
If the neutral safety switch has been bypassed (easily done with a jumper wire), it could start in any selection of the shifter
Old Jan 8, 2013 | 09:26 AM
Joe,
Yes. The NSS is in the column. If the linkage rod between the column and the trans is misadjusted, it is very possible that the steering column (and thus NSS) would be in PARK and the car would start normally, but the trans would be in a position just out of PARK, thus the parking pawl would not be engaged.
Old Jan 9, 2013 | 06:59 AM
Bitburger's Avatar
Thanks all for the responses
wolfman98
Dec 10, 2011 10:08 AM
TRW
Jan 21, 2011 05:38 AM
ls442
Nov 11, 2010 10:45 PM
badboy2003
Tech Editor's Desk
Sep 2, 2008 12:11 AM
cutlass72
Jan 2, 2004 05:26 PM
