Testing new camera.
Testing new camera.
I got a new Pentax XG-1 and trying it out. I know very little about cameras but I am happy with this one so far. Here are some sample pictures of our automatic Jetfire. I had to resize them from Photobucket because they were to big. After resizing them, they don't look any differant than our old camera pictures. Our old one quit on us. Just need to learn all the little settings and adjustments I can make.
Try taking pics on pavement, not grass, perhaps with more sun. Look at a magazine and you'll see most avoid the grass because the green affects the color of the car.
Also, buy a 'dummies' book (although not one of those specific "Dummies" books) that is specific to your camera model.
The worse time to take pics is during midday with a high sun, best times are in the morning & late afternoon with a low sun. Midday is fine if it is partly cloudy, I would strongly suggest that you buy a polarizer.
I do not think you need a polarize filter to photograph your car. What they do is increase color saturation and reduce flare on reflective surfaces and you will lose 1 stop of light. They are best suited for landscape photography. What you want to do is set a custom white balance in the lighting that you are working in. That will keep your colors true without any shifts. I also suggest you try using your camera in aperture priority, it will most likely be marked on your camera as a "A". That will give you control over the depth of field and the camera will balance your exposure with the appropriate shutter speed. You also might want to try switching your metering to center weight when photographing your car, this way your camera is exposing for the car it will help a lot if you are shooting against a bright sky.
The pictures look great to me!
I have had 3 pentax DSLR's and happen to love them.
The real difference will be if you decide to step up and get a really great lens.
I have a 10-20mm that I love shooting with at car shows. You can get the entire car in the shot and edit the folks walking around out for the most part.
And although you don't need a polarizer, they are great when shooting cars.
-They darken the sky
-They can dial out or up certain reflections and cut glare on windshields.
Have fun shooting and learning your new camera!
-Pete
(CPL stands for circular polarizer)
(Here's all you need to know)
http://oneslidephotography.com/creat...arizer-filter/
Enjoy!
-Pete
Enjoy!
I got a filter on it that says "can be used as a permanent lens protector". The guy at the camera store said it is clear enough that it will have little affect on my pictures. I know it can take filters but not sure what they really do. I don't even know enough to be dangerous.
Great information guys, This does help with what I need to look up and learn more about.
I'm fairly new to using a polarizing filter, but i read that it's most effective 90 degrees from the sun. I was out using mine today while taking some fall landscape shots, and it does make a huge difference.
When I was younger I messed around with a Canon eos 750 then moved up to a 620. this was before digital. I liked to take long exposures at night with a tripod. Point the camera at the stars and leave the shutter opened for 15-30 min. Always wanted to try it with fire Flys but was never in the right place at the right time.
Railguy
Railguy
ah64pilot
Sep 19, 2012 10:55 AM
mugzilla
Mar 27, 2010 07:03 PM
