Stupid question of the day
Old Jan 28, 2009 | 01:43 PM
Willidog's Avatar
Official Tire Kicker
I know 68 and 69 Cutlass shared the same fenders, are the doors identical as well?
Old Jan 28, 2009 | 02:12 PM
442Harv's Avatar
The hardtops are different, as 68 has a side vent window. I think the 2 door post cars use the same door.
Old Jan 28, 2009 | 02:15 PM
442Harv's Avatar
Also the fenders are different, the hood spring brackets are different so the fenders is a little different.
Old Jan 28, 2009 | 02:43 PM
Willidog's Avatar
Thanks. Now my day is ruined. :-)
Old Jan 28, 2009 | 02:45 PM
The fenders are different but interchangeable so long as you either swap the hinges or redrill the holes. The 68 hood hinges use three bolts, the 69s use two (in different locations). There is actually a third design as well. The factory service fenders actually had both sets of holes drilled and nuts spotwelded in place. These fenders will fit either a 68 or a 69.
Also note that the chrome spear on the top of the fender, just below the peak, is also different between 68 and 69. The 68s used a two-part spear with the front portion a die-cast pot metal part and the rest stainless. The 69s used a one-piece spear that was all stainless.
Old Jan 28, 2009 | 02:51 PM
68Tom's Avatar
From experience, I can tell you you really don't want '68 hood hinges unless you enjoy hitting your head. I always feel like the hood is closing in on me when I'm under it.
Old Jan 28, 2009 | 04:29 PM
Alb's Avatar
Alb
Joe,
The 68 uses 2 bolts and the 69 3.
Alb
Old Jan 28, 2009 | 07:15 PM
Originally Posted by Alb
Joe,
Alb
Thanks. That's what I get for posting from work when I should be working...
Old Jan 29, 2009 | 05:26 AM
68ragtop's Avatar
Geez, I thought it was only me!
Old Jan 29, 2009 | 09:53 AM
64Rocket's Avatar
If you redrill the fender and use the '69 hinge, will it mount to the '68 hood and open higher?
Gene
Old Jan 30, 2009 | 04:58 AM
19684424speedconvertible's Avatar
Gene
Thats a good question,I`d like to know too because I have a nos pair of the gm replacement fenders with the holes and nuts for both 68 and 69 hinges.
Old Jan 30, 2009 | 01:53 PM
daves62's Avatar
wow thats a long name
Old Mar 17, 2009 | 12:53 PM
Willidog's Avatar
OK, to continue with the stupid question of the day...since 68 and 69 fenders are interchangeable with minor differences, what about 4 door fenders? Are they the same as the two door fenders? In other words, can I buy fenders from a four door and put them on my two door model?
Old Mar 17, 2009 | 03:04 PM
Yes. 2dr, 4dr, wagon are all identical from the firewall forward.
Old Mar 17, 2009 | 05:47 PM
Willidog's Avatar
Awesome, thanks Joe.
Keith
Jerry the wrench
Oct 21, 2014 02:41 PM
auto_editor
Apr 26, 2013 05:19 PM
MDchanic
Mar 27, 2012 07:54 PM
Tedd Thompson
Sep 24, 2010 07:32 AM
gearheads78
Dec 18, 2009 06:15 AM
